It is currently Fri Nov 20, 2026 10:02 am
 Post subject: Crystal ball.
PostPosted: Sun Jul 21, 2013 12:23 pm  (#1)
I think I just got lucky with this. I was following a photoshop tutorial for making a crystal ball and was getting stuck on quite a few of the instructions. There didn't seem to be any way to replicate some of what was being said with Gimp so I just started messing around and came up with the above image. I used the Render/Nature/Flame filter for the smoky effect inside the ball and also the Apply Lens filter to give a curved shape to it.
I'm using this image over at my DeviantArt profile. It's for a link to Dark News magazine where I am now - without the slightest idea what I'm doing - the official astrologer.
DeviantArt gallery
 Post subject: Re: Crystal ball.
PostPosted: Sun Jul 21, 2013 12:52 pm  (#2)
looks like a real photo of a marble!
PostPosted: Sun Jul 21, 2013 3:26 pm  (#3)
caz: a good looking composition! i think the ball needs some highlights to the left to give it some volume, though.
PostPosted: Mon Jul 22, 2013 1:07 am  (#4)
Could looking ball, like the pattern created with the flame filter.
PostPosted: Mon Jul 22, 2013 11:51 am  (#5)
Thanks. I was pleased with the way it turned out.
I guess you mean on the left hand side where the edge of the ball is lost in the dark? I didn't want to crowd out the inside of the ball with too much detail, but yeah it could do with some more definition at that point. Thanks for the tip.
Thanks. I never used to use the fame filter much on my old machine as it took too long to run on large images. It works much better now that I've got a faster machine.
DeviantArt gallery
PostPosted: Tue Jul 23, 2013 5:08 am  (#6)
I like it Caz. Nice font too.
PostPosted: Tue Jul 23, 2013 12:23 pm  (#7)
Thanks, Erisian.
The font's called 'New Gothic Style.' I got it from dafont. It's so good that these people just give this stuff away.
DeviantArt gallery
PostPosted: Wed Jul 24, 2013 11:59 am  (#8)
I like it. Which filter did you use for the lightning effect? I got stuck when following the photoshop tutorial and couldn't figure out a way to make the lightning with Gimp, so I went for flames instead.
DeviantArt gallery
PostPosted: Thu Jul 25, 2013 12:17 pm  (#9)
Thank you, conbagui, that works great.
Actually I ran through the instructions about four times before I realised how important the brush size is. It would appear that anything less than about 100 pixels and the effect won't work.
DeviantArt gallery
PostPosted: Thu Jul 25, 2013 1:58 pm  (#10)
Both of those are very cool! Do you have a link to the tutorial? I might like to try that one day.
PostPosted: Thu Jul 25, 2013 3:42 pm  (#11)
Thanks, I want to try this when I get done with my current project!
