It is currently Fri Nov 20, 2026 8:46 am
 Post subject: Pilgrimage
PostPosted: Sun Jul 21, 2013 7:37 pm  (#1)
The Off road Temple of the Brotherhood of the Holy Grapes.
They usually go off road also to avoid discussions with Traffic Patrol :
their Cult is licit and respected but they believe that the Beloved Juice of the Holy Grapes makes more audible the indication of the Lord ,
the only that may indicate the Right Way , the Real Driver .
So they always drive totally drunk
There is no danger because the Lord is their real Driver , ..anyway if you see them approaching better step out
The temple done with M3D , the Bg was a cool image from wikimedia , crop and edited with gmic
 Post subject: Re: Pilgrimage
PostPosted: Sun Jul 21, 2013 7:52 pm  (#2)
are the brothers very small or is the temple bigger on the inside then on the outside ?
PostPosted: Mon Jul 22, 2013 4:52 am  (#3)
Both
But maybe i must change BG (also for the lights ..)
PostPosted: Mon Jul 22, 2013 5:18 am  (#4)
photo comix: i agree about the background - the temple looks fantastic in itself, i really like the lighting and the colours, but it doesn't really work with the background. i hope you find another road, though! i love the story, it's like cut out of a terry pratchett book :). i can imagine the heated conflicts when the brothers meet the trafic patrol...
PostPosted: Mon Jul 22, 2013 5:42 am  (#5)
I try hard but it is really difficult find a adapt road , proportions and lights are always incompatible.
I fear i will end painting one .
PostPosted: Mon Jul 22, 2013 7:26 am  (#6)
Yes , not only they are convinced that the Lord is their guide and the Real Driver , but they consider a sacrilege contest the Lord Precedence rights, because His the right way ,and any doubt would be Blasphemy
So they never stop or slow down at crossroads...:gaah
PostPosted: Mon Jul 22, 2013 7:53 am  (#7)
Better BG except that now the Temple look static
BTW
It is not the same Temple similar but not the same , difference is on top rows that open to become a "U" , while the other is a close circle
