It is currently Fri Nov 20, 2026 9:58 am
 Post subject: Neon Esper
PostPosted: Fri Jul 26, 2013 9:24 pm  (#1)
i wanted to make a neon sign for quite some time, but its pretty hard
when i started learning Gimp, i used to look at a lot of lightsabre tutorials
now rewatching them again, i dont like any of the techniques and good neon tutorials are hard to find too
i picked some inspiration from a very lengthy PS tutorial, but other than ideas, i came up with all of it myself
its okay for a start, i guess
the tubes were made in Inkscape, which was hard for me too
im not very good with the Bezier tool, but doing it, helped a lot with learning it better
will try this again some other time
 Post subject: Re: Neon Esper
PostPosted: Fri Jul 26, 2013 9:37 pm  (#2)
Nicely done, very impressive Esper!
PostPosted: Fri Jul 26, 2013 9:54 pm  (#3)
Very nice! Only thing I'd say to improve is make the color less white and more "neon" in color. :>
Other than that it's perfect! :D
Good job, nice work! :D
PostPosted: Fri Jul 26, 2013 10:06 pm  (#4)
thanks Odin and Moko
i had stronger blue glows at first
it looked better this way, imo
thinking about it, the whole thing has a pretty cold vibe to it
all the grayscale with only the blue as colour.....
PostPosted: Fri Jul 26, 2013 10:25 pm  (#5)
Well now that I look at it again, it looks kinda old movie-ish. :>
PostPosted: Fri Jul 26, 2013 10:34 pm  (#6)
good tube shapes, you did very well with inkscape.
PostPosted: Sat Jul 27, 2013 12:53 am  (#7)
That's cool !! :clap :clap :clap
PostPosted: Sat Jul 27, 2013 1:59 am  (#8)
Wow, you can see the tubes
PostPosted: Sat Jul 27, 2013 2:11 am  (#9)
The first neon sign that actually looks like a neon sign. Cool!
http://tonysteeleebw.deviantart.com/
PostPosted: Sat Jul 27, 2013 11:27 am  (#10)
Very neat!
Doesn't seem like you had any problem with Bezier tool. Smooth and precise splines.
If I may, my nickel of constructive critique. Never mind, you've done a very good job!
PostPosted: Sat Jul 27, 2013 11:33 am  (#11)
please do ! :)
PostPosted: Sat Jul 27, 2013 11:59 am  (#12)
OK, you asked for it :mrgreen:
Get rid of inner shadows. If the neon tubes are the strongest/only source of light, it's not clear where the shadows are from.
The halo of light radiance is a bit too strong/spread, unless there is a foggy atmosphere around.
I worked on neon sign a little while ago and searched for reference images.
Suggestions.
The whole composition would gain if you gave it slightly side-view perspective rather than almost orthogonal. Your skills are up to that task, i have no doubt.
It would look more interesting with real brick texture on the BG. I don't think it would take the focus off of the main object.
PostPosted: Sat Jul 27, 2013 5:13 pm  (#13)
One thing I've noticed from having looked at hundreds of images of neon signs is that the mount of "white light" one sees depends greatly upon the color of the tube. Blue, for example, tends to only show the white of the tube on the inside edge. The other caveat to neon is in that one can visibly see the blacked out tubing which connects one letter to the next. It's an incredibly difficult effect to achieve with any degree of realism.
PostPosted: Sun Jul 28, 2013 3:56 am  (#14)
esper: :wow great job on that, brother! for realistic neon effect this is one of the best i've seen. i think i generally prefer the less realistic neon effects, though, they look more like my impression of neon signs than a photographic reproduction of them. still, if you want realism this is an impressive job.
PostPosted: Sun Jul 28, 2013 5:45 am  (#15)
That's lovely Esper - very precise work as usual and nicely lit.
PostPosted: Sun Jul 28, 2013 11:20 am  (#16)
thanks for all the comments, especially K1te and Mike !
i was thinking about your suggestions, K1te
all i can say is, im not so much about realism
while i find photorealistic 3D stuff impressive, its not what i would want to do
i agree about all your points regarding lighting and shadows and stuff but something was missing for me, as the piece seemed to work anyhow
then AnMal nailed it with her comment
i wanted it to look like a neon sign and in that way its good
i wasnt too happy with my result, because, well i rarely am (lol) and the greater goal is something else
this was just a first step or test
because i want to do something like this, some day
EDIT: oh and btw, the texture is real brick
i got it from texturemate.com
PostPosted: Sun Jul 28, 2013 11:37 am  (#17)
Nicely done in my opinion Esper.
PostPosted: Sun Jul 28, 2013 12:35 pm  (#18)
forgot to add the tutorial, that got the ball rolling
http://www.youtube.com/watch?v=PnCtDkXF5Pk
PostPosted: Sun Jul 28, 2013 1:43 pm  (#19)
your work is impressive and one of the best i've seen
i wasn't trying to push you in the direction of 3d photorealistic stuff :)
btw, creating realistically looking neon sign with 3D app didn't work very well for me in the past.
here you can see why
tbh, i like your work better than my own :bigthup
PostPosted: Sun Jul 28, 2013 1:47 pm  (#20)
i know K1te and i like hearing your input form a different angle
also i think your 3D neon sign looks great, dont know what you want
oh and thanks for all the compliments, thats very flattering
