It is currently Fri Nov 20, 2026 9:58 am
 Post subject: The hypno-net of the Rainbow Spider
PostPosted: Sat Aug 03, 2013 8:47 pm  (#1)
Even if hypno-net may be lethal most of the danger come by looking them ... or if you avoid looking to stumble inside one
But the spider is the real problem at soon you concentrate on the hypno-net to avoid it, the highly poisonous and mimetic Rainbow spider will attack you from behind your visual field.
Luckily the Rainbow Spider are very emphatic and will never harm you if you act friendly and you have some fry flies to offer.
(Rainbow Spider are greedy for fry flies and even mosquitos, better if with no ketchup and much larvae sauce . )
(i just found a folder of patterns i did time ago :paint ... this caught my attention... )
 Post subject: Re: The hypno-net of the Rainbow Spider
PostPosted: Sun Aug 04, 2013 4:57 am  (#2)
photo comix: i'm glad you only had the net, as i suspected (or i wouldn't have looked!), and not the actual spider... i liked the net, very neat work.
