It is currently Fri Nov 20, 2026 9:59 am
 Post subject: Diagnostic Patterns for Mad Doctors
PostPosted: Sun Aug 04, 2013 12:32 am  (#1)
Hallucinations may be dangerous but a early diagnosis may contribute to the cure
just stare the image below , are only squares , the colors are severe , everything is still ...nothing may move
...see points shifting position would be a hallucination :wh
But even if you had the sensation that something move don't worry...not yet !
Before worry better control again with a more accurate check... try again
Now if you see some ghostly movement in one of the figures , don't worry yet !
You may suffer only of hallucinations but not of epilepsy, so maybe you may relax
But better to check for epilepsy now :
try to stare at the images below, better one by one slowly and with fixed focus
:yes A good new you have nothing to worry about epilepsy ... if epileptic you will be no more here reading ! :jumpclap
 Post subject: Re: Diagnostic Patterns for Mad Doctors
PostPosted: Sun Aug 04, 2013 4:46 am  (#2)
photo comix: hehe, i'm glad i don't have epilepsy, but the migraine i had on friday tried to get back out of its cage for a while.
