It is currently Fri Nov 20, 2026 9:58 am
 Post subject: Challenge
PostPosted: Thu Aug 08, 2013 2:17 pm  (#1)
Nothing like a good challenge to get the creative juices flowing, isn't it? So, what can you do with this:
 Post subject: Re: Challenge
PostPosted: Thu Aug 08, 2013 3:11 pm  (#2)
PostPosted: Thu Aug 08, 2013 3:21 pm  (#3)
Just had to be done and thanks for the excercise ofnuts. Click on the image for the uber hirez result at Flickr. :)
PostPosted: Thu Aug 08, 2013 4:15 pm  (#4)
can't help but admire the perfection of this shot and obviously a good job on lens distortion correction.
makes it perfect for all kinds of symmetrical manipulations
PostPosted: Thu Aug 08, 2013 4:28 pm  (#5)
i love the triangle, K1te !
PostPosted: Thu Aug 08, 2013 4:47 pm  (#6)
@saulgoode/photocomix: Good one...
@lylejk: you never disappoint :) now expecting a "Josephine" paisley by AnMal, and a "French Imperium" text design by Esper...
@K1TesseraEna: there is an Imperial Eagle on the ground at the dead center, so shooting for the center square in th evault from there was a good way to be very close to the vertical. Still spent a good half hour with the Rotate and Perspective tools to make all that really square and symmetrical. The triangle is a nice find.
PostPosted: Thu Aug 08, 2013 5:12 pm  (#7)
you made this shot, ofnuts!? kudos! I knew about the mark on the ground but still....
I thought one would need complicated lens correction plugin for different kinds of lenses in addition to rotate and perspective tool but you just proved me wrong. Very impressive, ofnuts!
PostPosted: Thu Aug 08, 2013 5:57 pm  (#8)
Agree with K1te; so perfectly balanced that I just horizontally flipped and set to lightened before merging down to create the horizontally seamless even toned result. Like your triangle too by the way K1te.
Thanks for the feedback as well offnuts. :)
PostPosted: Thu Aug 08, 2013 6:08 pm  (#9)
I just corrected it to be (quite) symmetrical and level. A keen eye will find the lens distortion (especially since it's shot with a wide-angle lens at is shortest length). Here is the original uncorrected shot:
PostPosted: Fri Aug 09, 2013 6:33 am  (#10)
I am as bad as Lyle when it comes to using Droste. :lol
You gotta love MathMap.
Or how about shattered. :)
PostPosted: Fri Aug 09, 2013 7:04 am  (#11)
Okay one more.
I had forgotten how long Wisps took to generate the layers. :)
PostPosted: Fri Aug 09, 2013 8:52 am  (#12)
nice art there in those jobs!
PostPosted: Fri Aug 09, 2013 8:54 am  (#13)
Yafu - very amusing, I like how it pushes the other arch out of the way.
PostPosted: Fri Aug 09, 2013 9:08 am  (#14)
How did you do the shatter Rod? I like it. :)
PostPosted: Fri Aug 09, 2013 9:11 am  (#15)
After doing the northen lights thought it could be possible to apply the same technique to a picture so here is the results.
PostPosted: Fri Aug 09, 2013 9:58 am  (#16)
Could not resist this
PostPosted: Fri Aug 09, 2013 3:27 pm  (#17)
Alien Skin Xenofex 2 filter. :)
PostPosted: Fri Aug 09, 2013 4:02 pm  (#18)
Nothing fancy, just made me think of things we miss if we don't look up once in a while.
PostPosted: Fri Aug 09, 2013 6:20 pm  (#19)
OK Rod; since you cheated, I'll cheat too. lol
Been on a pills binge of late (posting most elsewhere) so why not here too. Used a lot of GIMP tricks (and some other ones) to add shading for dimentionality since DAP doesn't do such a good job of that. DAP time around 1 to 2 minutes; full rendering over 30 minutes just to give you some perspective. lol
Now, if anyone here knows how to shade a relatively flat photo to give it dimentionality, then please share since this is a heck of a lot of work for a filter guy and I'm lazy. :)
PostPosted: Sat Aug 10, 2013 6:37 am  (#20)
Well ofnuts didn't say we had to use GIMP primarily. :)
Besides i can run Alien Skin effects through GIMP and PSPI. :lol
Okay so now where did you get the pill sprites? Those are awesome.
