It is currently Fri Nov 20, 2026 10:00 am
 Post subject: The Color of Money Abstract
PostPosted: Sat Aug 10, 2013 6:05 am  (#1)
Two star paths - scale one to half size
flip small star vertical
run path in-betweener - 50 paths
merge visible paths
stroke soft 1 pixel soft brush
alpha to select fill
new layer
colored money green
new from visible
If you do not have MathMap, get it. :)
Filters>Generic>Mathmap>Droste - wait patiently for render - have cup of coffee
new layer black and run super nova exactly center with color spikes
set black layer to hue mode. :)
Just the star after in-betweener , before Mathmap Droste, and with the colored nova layer added.
 Post subject: Re: The Color of Money Abstract
PostPosted: Sat Aug 10, 2013 6:14 am  (#2)
Rod, nice work but I actually prefer just the star on its own.
PostPosted: Sat Aug 10, 2013 6:18 am  (#3)
rod: wow. that looks sooo good! and it must have taken forever to render it.
PostPosted: Sat Aug 10, 2013 6:27 am  (#4)
Thank you Anmal. :)
It only took about 12 minutes just in Droste alone. :lol
The entire image took about an hour to create.
Thanks he4rty. You really have to appreciate the complexity of Droste to like the outcome of the filter. :)
PostPosted: Sat Aug 10, 2013 2:11 pm  (#5)
I love the pentagram star. Looks almost like origami.
