It is currently Thu Nov 19, 2026 7:02 am
 Post subject: More tests on Lions
PostPosted: Sat Dec 11, 2010 9:59 pm  (#1)
well i am very happy of my 2 gmic filters, soon must be ready a new version (with possibility to control opacity when merging )
I had some fun testing different combinations, a lot of possibilities leading to very different results but all with something in commune...a graphic boost :geek
ALMOST BW
Little Shy Lion BW by PhotoComiX, on Flickr
RED & YELLOW
Little shy Lion by PhotoComiX, on Flickr
VERY REALISTIC PAINT
Little Shy Lion by PhotoComiX, on Flickr
60 MOVIE POSTER
ADD MORE DEPTH ?
timido-giallo.sharp by PhotoComiX, on Flickr
ORIGINAL
Little Lion by GIO®D@NO™, on Flickr
Only change with the original ,before editing with gmic, was a tweak to hue and saturation to get more reddish colours
PS Oregonian
I noticed that sort of pixelation with default setting you got at your first try
i will modify the default, that pixelation is easy to avoid (just raising a bit the complessive or the pencil smoothing ) but i will search a different default
 Post subject: Re: More tests on Lions
PostPosted: Sun Dec 12, 2010 12:21 am  (#2)
I've said it before and I'll say it again! Your work is awesome!
My Sigs = My Photos
PostPosted: Sun Dec 12, 2010 8:37 pm  (#3)
looks awesome
like the red and yellow one the most
I AM DARK LITE
WELCOME TO NoGo
PostPosted: Sun Dec 12, 2010 10:50 pm  (#4)
well a last test for "kool sketch "
ORIGINAL (by Tambako the Jaguar On Flickr)
Roaring lion by Tambako the Jaguar, on Flickr
