It is currently Fri Nov 20, 2026 10:01 am
 Post subject: Bumped - Rusty Text
PostPosted: Fri Aug 16, 2013 1:27 pm  (#1)
Just playing with bump maps and some text. :)
XCF workspace file attached.
Bumped.xcf [3.67 MiB]
Downloaded 135 times
Font name is - CGF Arch Reactor
 Post subject: Re: Bumped - Rusty Text
PostPosted: Fri Aug 16, 2013 1:31 pm  (#2)
quite nice Rod. It looks like it could be made into smokin - hot - stone.
PostPosted: Fri Aug 16, 2013 1:40 pm  (#3)
Thanks Molly. I was testing out some new glowing colored shadow techniques. :)
I think it looks pretty hot also.
PostPosted: Fri Aug 16, 2013 3:11 pm  (#4)
that looks promising, Rod !
i see from the xcf you used that advanced dropshadow script (forgot the name)
PostPosted: Fri Aug 16, 2013 3:19 pm  (#5)
Heh! BUMPED. lol
PostPosted: Fri Aug 16, 2013 3:21 pm  (#6)
Nicely done Rod! :)
PostPosted: Fri Aug 16, 2013 9:19 pm  (#7)
Thanks folks. :)
Esper i believe it is called Drop Shadow Advanced.
http://registry.gimp.org/node/28333
PostPosted: Sat Aug 17, 2013 8:38 am  (#8)
Thanks folks. :)
