It is currently Fri Nov 20, 2026 10:01 am
 Post subject: what do you think of this tracklist artwork ?
PostPosted: Sun Aug 18, 2013 2:21 pm  (#1)
so on my music board there is a guy called Dj Extreme
he posts free mixes for everybody to download
i think hes a nice guy and i wanted to trwat one of his mixes with some tracklist artwork
heres what i came up with - was quite difficult for me to get right and i dont want to spent another couples of hours on this
it was supposed to be quick and simple, lol
any kind of input very much appreciated
oh btw, the name 'Dj Die' has nothing to do with death, lol
it comes from Daniel and has been the prodcuers name since the 90ies
EDIT:
made another version
 Post subject: Re: what do you think of this tracklist artwork ?
PostPosted: Sun Aug 18, 2013 2:59 pm  (#2)
EDIT:
I think it's pretty good. The letters are very clean/smooth.
IMHO... it does lack a sense of flair, that can sometimes be associated with the music scene/industry.
Also, the space between the words 'DJ Die' and 'Remixes' could have been given a bit more separation. The numbers before each song seem to also need some kind of separation or maybe a colon or a full stop/period.
PostPosted: Sun Aug 18, 2013 3:10 pm  (#3)
EDIT:
It looks really good but that bg needs something. Maybe some grunge?
PostPosted: Sun Aug 18, 2013 3:12 pm  (#4)
thanks Wallace
i agree about the lack of flair, but no ideas at the moment how this could be improved
as i said, it was supposed to be quick and easy, lol
dont know about the space between die and remix
but im not doing this all over again - so no to that tip, lol
the tracklist was copy and pasted from dj extreme`s tracklist, so its all his fault
PostPosted: Sun Aug 18, 2013 3:47 pm  (#5)
Yes the Tracklist has something missing, something that makes it unique. Try to play with the listing style too (let it look like stairs for example)
If you do something with a background try to "mute" it or else it would be too difficult to read the tracknames. Maybe you should look at real backcovers on CDs you own.
My Youtube Channel with Timelapse Videos: -> bloodywing1 :: My Facebook Page / Art with MyPaint and GIMP
PostPosted: Sun Aug 18, 2013 3:53 pm  (#6)
Hey Esper.
I reworked the image a little, only to demonstrate what I mentioned. Would it be alright for me to post it here for you to view?
PostPosted: Sun Aug 18, 2013 4:03 pm  (#7)
I agree with Wallace, the main letters (the large ones need more space between the letters)
The list below could be 01 - Clan 02 - DJ and so on. I wouldn't change the background, it would make it too busy and crowd out the text.
Other than that...very good
PostPosted: Sun Aug 18, 2013 4:30 pm  (#8)
hm, not sure what to make of it
what do you mean with mute ?
Hey Esper.
sure ! :bigthup
thanks molly
will see about changing the tracklist
i kind of agree about the background, but i tried to incorporate Rod' suggestion
it looks good, but its not really what i wanted it to bein the beginning
EDIT: with periods after each number
PostPosted: Sun Aug 18, 2013 4:55 pm  (#9)
For me the white fuzzy outline contradicts the 3D effect... you can't have a 2D outline on a 3D drawing. And if its a 3D outline of where the letters rest on the background, then it's wrong (it shouldn't be visible on top edges).
Also, the 3D perspective calls for everything to follow that perspective, but a track list with perspective could be hard to read.
Typography is a bit erratic, it uses Title Case ("The Planet Plan") or not ("Play it for me"). It lacks a bit of space between the track numbers and the titles (and maybe some punctuation: "12:" or "12."). And speaking of track numbers, leading zeros are OK for file names but not fit for human consumption.
PostPosted: Sun Aug 18, 2013 5:12 pm  (#10)
funny enough, i have seen that on several packages for chips, mini-salami, chocolate, etc.
thats where i got the idea from
i agree about the top edges
tried that and you are right, it looks crap
EDIT: i think i liked the old outline better
PostPosted: Sun Aug 18, 2013 5:23 pm  (#11)
Here is my example of the things I mentioned. Sorry Espar if you feel I chopped up your image.
PostPosted: Sun Aug 18, 2013 5:28 pm  (#12)
thanks Wallace
dont feel bad for showing me your vision !
you can always edit my stuff if you like, dont have to ask for permission
i see what you mean, i was under the impression you wanted me to make the space between dj die and remixes smaller
PostPosted: Sun Aug 18, 2013 6:18 pm  (#13)
Definitely more like it at least for the track list. But I agree that this outline isn't much better than the original.
PostPosted: Sun Aug 18, 2013 6:56 pm  (#14)
Esper wrote:
thanks Wallace
You're welcome Esper.
Just the opposite, as you can see form my reworking of your image.
Also the fuzzy out line is good, but as others have mentioned, it looks odd against the 3D lettering.
To me, the fuzzy white outline looks like the letters are sitting on a cutout of 'white grass' and are not actually part of the lettering itself.
I do still like that fuzzy outline effect though. ;)
PostPosted: Mon Aug 19, 2013 7:59 am  (#15)
"mute" means that the colors are not as vivid as regular colors. See here: https://en.wikipedia.org/wiki/Colorfulness
Quick tutorial how to mute an image: http://www.gimpology.com/submission/vie ... or_effect/
PostPosted: Mon Aug 19, 2013 9:40 am  (#16)
thanks for the links !
i guess i understand now what you mean
is there another way to find a mute colour without using the technique you linked to ?
PostPosted: Mon Aug 19, 2013 9:50 am  (#17)
You can try something similar with grey layers and play with the layermodes. I think you can reach a similar effect with that.
And open the palette selector dialog in GIMP there should a muted color palette somewhere called "Muted"
PostPosted: Mon Aug 19, 2013 9:54 am  (#18)
i wonder if you can just reduce the saturation of any color
EDIT: i had a look at the Mute palette
there isnt any color that matches something like i used for the background, but i get the idea, of what a muted colour would look like !
PostPosted: Mon Aug 19, 2013 10:03 am  (#19)
I really like a lot that kind of outlined that have 3D letters.
I'd like to see how it looks applied also in the song list below :)
PostPosted: Mon Aug 19, 2013 10:15 am  (#20)
i dont understand what you mean but be my guest
Dj Die vs Dj Extreme - ESP.rar [4.11 MiB]
Downloaded 98 times
