It is currently Fri Nov 20, 2026 10:02 am
 Post subject: Hot Number...
PostPosted: Mon Aug 19, 2013 5:41 pm  (#1)
Made these a little while ago. I hope you weren't expecting anything different. :hehe
hot numbers.xcf [1.52 MiB]
Downloaded 147 times
 Post subject: Re: Hot Number...
PostPosted: Mon Aug 19, 2013 5:45 pm  (#2)
very nice !
how did you make these ?
PostPosted: Mon Aug 19, 2013 5:52 pm  (#3)
Esper wrote:
very nice !
I was afraid someone was going to ask that. :hehe
PostPosted: Mon Aug 19, 2013 5:57 pm  (#4)
do you want me to scream tutorial next ? :mrgreen:
PostPosted: Mon Aug 19, 2013 6:04 pm  (#5)
Did you drag the fire colors up with the smudge brush.
PostPosted: Mon Aug 19, 2013 6:29 pm  (#6)
I was thinking black crayon graffiti.
Looks great Wallace. :)
PostPosted: Mon Aug 19, 2013 6:40 pm  (#7)
That is awesome! I like it. Not what I was expecting when I clicked on it. lol!
PostPosted: Mon Aug 19, 2013 6:42 pm  (#8)
Not what I expected either. :lol
Nice work! :D
PostPosted: Mon Aug 19, 2013 6:44 pm  (#9)
my guess is the flame filter
PostPosted: Mon Aug 19, 2013 7:57 pm  (#10)
I made the base text and duplicated it, blurred it, did 'Wind' and then did 'Ripple'. Duplicated this layer and blurred, then set the layer mode to dissolve lowering the opacity.
Used the 'Render'> Nature> Flame. Made a nice flame using red and yellow. Flipped, rotated and scaled the flame render for each number and placed it behind everything.
I was making a tut, but only got about 1/4 the way through and my Gimp crashed (auto save not enabled). I only managed to get 4 screenshots of how I did the base text, but wasn't able to get to the making of the flames.
PostPosted: Mon Aug 19, 2013 10:20 pm  (#11)
There's an auto save???
How do I enable that? Please tell me! plzplzplzplzplzplzplz!!!! *puppy eyes*
PostPosted: Mon Aug 19, 2013 10:40 pm  (#12)
Yes there is an 'Auto Save'.
There is a thread about it here on GC, but I'm not sure where.
In the mean time I'll look in my Gimp files and try to find the correct file/plugin and send you a link or attach a file so you can download it, if necessary. ;)
I found the plugin, it's a python-plugin, so you need to have python installed.
autosave_a.zip [4.7 KiB]
Downloaded 228 times
PostPosted: Mon Aug 19, 2013 11:27 pm  (#13)
I have GIMP 2.8, so can I install this? I read that python was built in to 2.8.
PostPosted: Mon Aug 19, 2013 11:39 pm  (#14)
You should have python installed, but it dose depend on which Gimp build you have installed. Otherwise, you should be able to install this plugin.
I'm using Gimp 2.6.11 and had to install python myself.
If you place this file into your plugin folder, it should work for you.
PostPosted: Tue Aug 20, 2013 6:29 am  (#15)
Awesome effect. Very unique look.
Does anyone know how you could take something like this and turn it into a font?
PostPosted: Tue Aug 20, 2013 6:53 am  (#16)
this was posted this morning by Kevin...
First hit: Autosave on the Gimp Registry: http://registry.gimp.org/node/20875
Fifth hit: Python version discussed here on GimpChat: viewtopic.php?f=9&t=983
PostPosted: Tue Aug 20, 2013 10:45 am  (#17)
I don't wanna take away from your thread so I'll go to the installation one you made and ask there...Thank you!
PostPosted: Tue Aug 20, 2013 12:28 pm  (#18)
Nice effect wallace.
PostPosted: Tue Aug 20, 2013 12:36 pm  (#19)
Thanks He4rty. ;)
PostPosted: Tue Aug 20, 2013 7:01 pm  (#20)
I tried ... not even close
This effect was really cool Wallace!
Edited:
neither do I. :hoh
:lol
bbbbbbbbbbbImage
