It is currently Fri Nov 20, 2026 11:03 am
 Post subject: Doodles
PostPosted: Fri Aug 23, 2013 12:32 pm  (#1)
Would really like to get back into drawing and using gimp as my main medium but need to practice a lot, so just to get the feel of the tablet and gimp, done what I know best and just started to draw some quick cartoony doodles, most only took about a minute and these are some of the better ones.
I have always prefered pencil drawing to painting so does anybody know of some good beginner pencil drawing tuts, thanks
 Post subject: Re: Doodles
PostPosted: Fri Aug 23, 2013 12:36 pm  (#2)
Nice doodles. :)
PostPosted: Fri Aug 23, 2013 12:39 pm  (#3)
Your doodles are better than my finished paintings he4rty! As far as figure drawing is concerned I can't think of anything more simple and effective than Manga techniques. Later on you might want to study anatomy and life drawing but Manga is a really good start.
PostPosted: Fri Aug 23, 2013 12:44 pm  (#4)
Thanks Erisian, I must be honest I cringe at the word Manga, I think its because da is just so saturated with it.
PostPosted: Fri Aug 23, 2013 1:35 pm  (#5)
If you change the eyes and hair on manga you get comic art. ;)
Seriously though, I do illustration work all the time. What sort of drawing are you interest in?
PostPosted: Fri Aug 23, 2013 1:38 pm  (#6)
I think to start with I'm just playing around with brushes and settings to get what I feel is a realistic pencil line and shade, also to those who do painting/drawing do you use the view dot-dot or not.
PostPosted: Fri Aug 23, 2013 1:41 pm  (#7)
Dot-dot?
PostPosted: Fri Aug 23, 2013 2:06 pm  (#8)
Here is a Link to a photo I have just taken of some pictures I draw back when I was 16ish almost 30 years ago, this is what I used to enjoy doing most and where I would like to get back to and better.
I suppose I just don't know where to start.
PostPosted: Fri Aug 23, 2013 2:18 pm  (#9)
Ah, do you mean "dot for dot" view? In short, no, never. I work at 300dpi, and my monitor is nowhere near that resolution. :D
In fact, the gimp docs recomend only enabling this mode if you are working on web graphics, and nothing for print:
http://docs.gimp.org/nl/gimp-view-dot-for-dot.html
For pencil drawing in GIMP, I'd start by testing out some of the pencil brushes, like these posted by a DA user: http://elmerucr.deviantart.com/art/Real ... P-57810771
Then I'd probably key the opacity and size to pressure using a wacom tablet.
I don't create pencil drawings in GIMP, but I do paint in GIMP. It depends on what you want your end result to be, but looking at your old drawings (which are pretty decent!), that's where I'd start.
PostPosted: Fri Aug 23, 2013 2:29 pm  (#10)
Thanks, I found them brushes and downloaded them, Intial wasn't impressed as I kept getting jagged lines when drawing then realised I'd left the snap to guide feature on, Duh.
I have download the gps presets and brushes and having a play around with them.
Now to find a descent walk through tutorial site.
PostPosted: Fri Aug 23, 2013 3:16 pm  (#11)
Heh! I've been guilty of that error (snap to guide). Glad it's working for you. Looking forward to seeing what you come up with!
Maybe I should try pencil drawing in GIMP. I haven't done it on anything but paper for a year now. I usually sketch a very light outline for shape reference, then painstakingly layer colour over it to achieve the effects I want. The results are illustrations like this one I did for a fellow who wanted a fox-human in a classical pose: Image
PostPosted: Fri Aug 23, 2013 3:26 pm  (#12)
I know what you mean and I don't do Manga myself but the way they simplify the drawing of the figure is very useful.
CRogers - beautiful work of art.
PostPosted: Fri Aug 23, 2013 3:37 pm  (#13)
Thanks! I have to go paint a real room now with white paint and a roller. If there's anyone who can write a script to get GIMP to do that, I'd be infinitely grateful! :hehe
PostPosted: Fri Aug 23, 2013 3:43 pm  (#14)
I like the doodles :D You should draw caricatures of the GC members
PostPosted: Fri Aug 23, 2013 6:01 pm  (#15)
CRogers - Thanks for the help and nice image.
Erisian - Thanks, I shall have to have a look into it, I suppose its no different from when I was a kid except then it would be copying characters from the beano or dandy.
merrak - Thanks for the comment, I think I'm a long way off doing caricatures at the moment.
