It is currently Fri Nov 20, 2026 11:06 am
 Post subject: GC contest :"Tweak the Reference"
PostPosted: Sun Aug 25, 2013 3:55 pm  (#1)
Well i have no authority to launch a GimpChat Contest, but i may propose one
"TWEAK THE REFERENCE" :
1) You may do a painting using as reference
2) you may use as lineart , as base for a color work
3) you may use any gimp tool or filter , even only filters and you may use mypaint
4) you may respect or modify the original :
you may turn animal and human in aliens, mythological creatures , or whatelse you may image, add or remove whatever you like
5) Whatever you do should preserve some similarities with the original
6) WIP may be be posted and disussed on ( New gallery topic to be opened )
7 )Timelinefor the final submission .... to be discussed with the mod (2 weeks ? )
2 possible "References " to tweak :
1) a sketch of a Italian landscape of the 16 century , taken on the Tiber, the river crossing Rome
(but again you may respect or turn in a imaginary landscape or what your imagination may suggest, including just use as was the "pencils" at the base of a colour paint )
Landschap met wachtende reizigers en veerpont bij de oever van de Tiber, Jan Both, 1644 - 1652
from https://www.rijksmuseum.nl/en/explore-t ... -BI-4211,7
This is the Colosseum in Rome, as was used for centuries , seen by another dutch artist in the 17 century
Gezicht op de ruïnes van het Colosseum, Nicolaes Pietersz. Berchem, 1630 - 1683
https://www.rijksmuseum.nl/en/explore-t ... 83-A-277,5
You may use the first or the second "reference" ... or even mix !
 Post subject: Re: GC contest :"Tweak the Reference"
PostPosted: Sun Aug 25, 2013 5:04 pm  (#2)
Here is my go at it. :)
I just used your image PC.
PostPosted: Mon Aug 26, 2013 6:43 am  (#3)
Nice Rod !
I edited the first post to add another possible "Reference".
Do you think the rules are clear ?
Maybe we can pin the topic and give a timeline (i.e. 2 weeks )
Yesterday i posted a example of a (emulated ) gauche or acquarel work directly derived from a old incision
i don't repost here because didn't use the Images proposed ,but may be a example for similar tweak
message 7 here viewtopic.php?f=11&t=8356
PostPosted: Thu Aug 29, 2013 1:59 pm  (#4)
:bump No other submissions ?
Not even a WIP ? :hoh :gaah
PostPosted: Thu Aug 29, 2013 2:19 pm  (#5)
Your (excellent) examples of intimidating - but a quick test
PostPosted: Thu Aug 29, 2013 3:10 pm  (#6)
oh nice , :hi5 i like mostly the first cool cartoonish effect :clap
I was just playing with the same image ...
a wip for a incision fx
PostPosted: Sat Aug 31, 2013 12:10 pm  (#7)
Yes all i did was create a new gradient layer and smudge it according to colors i wanted each section to be.
You could alternatively create color spots and smudge them around also. Then the colored layer is set to a different mode. In my case DODGE mode.
Another way is to simply paint the colors in with the brush tool.
Pretty easy effect to create a colored sketch image from drawings. :)
In the first image i posted i used a gradient (red. green,blue), and filled the top layer with that gradient. Then i smudged the colors to color the image below. I did add some colors here and there also.
PostPosted: Sat Aug 31, 2013 1:55 pm  (#8)
@Rod
your technique is very effective and fast ,but the application may need some fine tune :
the green is perfect on the tree leaves but overlap often on the branches.
PostPosted: Sat Aug 31, 2013 9:09 pm  (#9)
PhotoComix wrote:
@Rod
Yes i did this one too fast wanting quick results. I should have taken my time and zoomed in a lot. :)
The coolest part of this effect is the top layer after the drawing is finished. If you view it by itself it looks almost like a painting. :bigthup
PostPosted: Sun Sep 01, 2013 3:24 am  (#10)
[ [url]Image[/url] ]
Wow Rod!
When I saw your painting, I thought super! :coolthup
Now seeing your technique, I loved that it is so simple! :paint
Thanks for sharing! :hi5
bbbbbbbbbbbImage
PostPosted: Sun Sep 01, 2013 1:45 pm  (#11)
Wow Rod!
No problem. Glad you like the results. You can also get many different outcomes from different layer modes. :)
PostPosted: Sun Sep 01, 2013 2:12 pm  (#12)
Another Wip not sure if the difference are evident, not only for the sketch style:
all the structure of the image was even if subtly modified by reducing the area without details
