It is currently Fri Nov 20, 2026 11:05 am
 Post subject: Playing with MathMap Droste-version 9
PostPosted: Mon Aug 26, 2013 11:24 am  (#1)
Anyone have the Droste 10 mathmap filter? I know its on Flickr, but every time i copy it i get a parse error running it in MM. I saved as an mm file and placed it in the Map folder. It doesn't show. I am guessing the code needs to be correctly pasted. So if anyone has the filter as an mm file can you attach it here?
Thanks! :)
 Post subject: Re: Playing with MathMap Droste-version 9
PostPosted: Mon Aug 26, 2013 11:55 am  (#2)
Nice effect
Thanks! :)
If is not here download/file.php?id=6028 then is included in MM
(i can't remember which version was included by default in MM, i remember that i added both the last because the more complete control, the previous because more simple to use ...there should be also a even more simplified version)
The zip contain ALL mathmap filters, not only the additional ones
PostPosted: Mon Aug 26, 2013 12:23 pm  (#3)
Droste is Droste 10
The difference is that has much more sliders and boxes
Droste 9 may do only a subset of what Droste (10) may do and nothing that Droste can't,
but yet who want apply the droste effect for the first time may prefer the 9 version because more basic
PostPosted: Mon Aug 26, 2013 8:43 pm  (#4)
Ahh thanks PC. I was wondering what the other Droste was. I always use 9 myself but i wanted to try this one so i guess i had it all along. Thank you sir. :)
