It is currently Fri Nov 20, 2026 11:05 am
 Post subject: Tomato - MyPaint Lighting Study + Video
PostPosted: Wed Aug 28, 2013 11:11 pm  (#1)
I was bored, so I decided to make a drawing, I started slowly then ended up thinking meh tomato why not? Then figured that I'd try to do what Griatch suggested a while ago to try and use different colors for shading...So that's what I did.
About 30-40 mins maybe an hour, MyPaint.
The random yellow in the air is supposed to represent a light source coming down on the tomato.
I have a video I made but it's saving now, I'll add it later here or in the Video section.
Video Here!!
Critique welcomed!
~ God Bless ~
~ Moko
 Post subject: Re: Tomato - MyPaint Lighting Study + Video
PostPosted: Thu Aug 29, 2013 12:57 am  (#2)
There's no bacon and lettuce!!!
Seriously apart from the tomato seems to be floating this is a very good painting.
PostPosted: Thu Aug 29, 2013 4:07 am  (#3)
Nice painting Moko but as he4rty said, the shadow needs to be more to the left so that it is underneath the tomato. This will place it firmly on the ground.
PostPosted: Thu Aug 29, 2013 1:12 pm  (#4)
I didn't like the shadow either, was just no matter what it seemed to look weird, I think I actually did domore to the left and it looked off..I don't remember though. xD
Thank you for the comments! :D
