It is currently Fri Nov 20, 2026 2:27 pm
 Post subject: Hot Off The Press
PostPosted: Mon Nov 04, 2013 1:34 pm  (#1)
Wanted to see if I could recreate the old style printing press blocks.
 Post subject: Re: Hot Off The Press
PostPosted: Mon Nov 04, 2013 5:39 pm  (#2)
I missed this earlier. It's really good. Did you use a photo texture for the metal?
PostPosted: Mon Nov 04, 2013 5:43 pm  (#3)
Nice job
PostPosted: Mon Nov 04, 2013 5:45 pm  (#4)
I used a copper texture I created forever ago and a copper texture I found online at some point in time. Mine was far too bright and the other was far too dull and Colors / Curves was washing out the mid-tones so I used both. It's not a complicated effect but there's always an issue with perspective when viewing 3D objects at a perpendicular. The letters either look raised or carved depending on the angle of view. :gaah
