It is currently Fri Nov 20, 2026 3:26 pm
 Post subject: Smokin'
PostPosted: Mon Nov 18, 2013 10:06 pm  (#1)
All that playing around trying to blend those two layers together has lead to the possibility of a means to create directional smoke within gimp using Gmic filters.
Thought I'd show the idea by using a candle that has just been blown out
 Post subject: Re: Smokin'
PostPosted: Mon Nov 18, 2013 11:10 pm  (#2)
He4rty I'd love to know how you created such perfect smoke from scratch
PostPosted: Tue Nov 19, 2013 3:15 am  (#3)
That is amazing he4rty!
PostPosted: Tue Nov 19, 2013 3:40 am  (#4)
Thanks for the Comments, planning a tutorial, just trying to refine the technique but I think this will be the image we will be using.
PostPosted: Tue Nov 19, 2013 5:07 am  (#5)
Waiting for the tutorial, i like the effect and wanna try it out.
PostPosted: Tue Nov 19, 2013 5:15 am  (#6)
Here are lots here to look through while you are waiting. [Gimp Chat Tutorials
PostPosted: Tue Nov 19, 2013 11:37 am  (#7)
Smoke in gimp for me is one of the easiest things to make. :)
PostPosted: Tue Nov 19, 2013 11:40 am  (#8)
very nice RD.
PostPosted: Tue Nov 19, 2013 11:57 am  (#9)
conbagui - It can be made thinner.
rdgracer71 - I'd be interested in how you created your effect as well.
PostPosted: Tue Nov 19, 2013 12:06 pm  (#10)
it's very easy. just draw a line with white. and then use the smudge tool to smear the white line you just drew. if you want to have shading in your smoke you would just need to add some gray to it or black. and just blend it with the smudge tool. you may have to play with the rate and pressure of the smudge tool to find the right setting to get what you are looking for. it's the first way i use to make clouds with when i started with gimp. i just used circle motions to smear the white line. and then i shrink the brush size and make more finer details of the smoke. i added a campfire to this image. just thought i would share it.
PostPosted: Tue Nov 19, 2013 12:15 pm  (#11)
Also i just wanted you to know i wasn't trying to take over your thread...
PostPosted: Tue Nov 19, 2013 1:55 pm  (#12)
Its nice to know different ways of creating an effect, Besides I stumbled over mine by accident so its most probably not the best of methods but seems to work.
Thanks for sharing your technique.
