It is currently Fri Nov 20, 2026 3:26 pm
 Post subject: Hy res seamless organic texture (photo or edited photo )
PostPosted: Wed Dec 11, 2013 12:31 pm  (#1)
I was uncertain if post here or in gimp resource, i believe may be a useful resource ,
then i decided that since i am a crazy Artist that believe his patterns ART i should post ;)
(Even if you are free to use as resource ;) )
Series 1 Organic Texture from Italy
:gaah I accidentally overwritten the original...oh well they work better as pattern at this or smaller size , i like larger because i may use also as "Effect Layer" ( opening the pattern as new layer) to add texture
Natural (yet modified to be seamless)
Same but with intensified and muted colours
Same pattern ,but even less realistic and more stylized
Ending with a almost abstract version
Again natural (but modified to be seamless)
and a more stylized version
now should pattern be squared or also rectangular patterns are fine ?
My are most rectangular and was missed a exception so
NEXT ORGANIC SEAMLESS PATTERN FROM CAMBODIA
 Post subject: Re: Hy res seamless organic texture (photo or edited photo )
PostPosted: Wed Dec 11, 2013 12:39 pm  (#2)
BTW are all in png format, there is no reason to convert in gimp ".pat" :
gimp may use as pattern png images ...just in case you wish add some to your pattern arsenal
PostPosted: Wed Dec 11, 2013 1:14 pm  (#3)
I love them all PC, snatched all but one, thanks
PostPosted: Wed Dec 11, 2013 7:52 pm  (#4)
@Molly
thanks :hi5
also are part of the Italian series , i was also confronting some "Make seamless " script
This time i converted to jpg to kept file size smaller ...
the same heavily edited , doesn't look more as grass but still does look very organic
