It is currently Fri Nov 20, 2026 3:25 pm
 Post subject: Pseudo-Hubble deep starfield from frosty window
PostPosted: Thu Dec 12, 2013 7:12 pm  (#1)
This was a personal challenge inspired by a friend's comment about my latest series of photos of my frosty windows. The idea grabbed me, and I took off with it, to turn a bit of sparkly frost into a fake photo of deep space. After several experiments, I turned out one that is not only the best so far, it was done mostly with the simplest tools.
1 Crop out a selection
2 Add black background layer
3 Add alpha transparency to photo layer
4 Select by color and delete until only the brightest spots are left (can be tricky, but worked well with this photo)
5 Gaussian blur slightly (2px)
6 Copy layer, select transparent, grow selection enough to delete smallest speckles and trim large "stars"
7 play with "Sparkle" (Lighting effects) filter on the last, simplified layer until there are some nice subtle rays
All layers are included in the final image. A little hand-retouching turned one odd-shaped "star" into a galaxy.
File comment: Cropped and manipulated selection
File comment: Original photo (reduced)
 Post subject: Re: Pseudo-Hubble deep starfield from frosty window
PostPosted: Thu Dec 12, 2013 7:50 pm  (#2)
That's really clever. It does remind me of the Hubble deep field. This is the Hubble Extreme Deep Field
PostPosted: Thu Dec 12, 2013 8:53 pm  (#3)
I visited the Hubble gallery to check my "authenticity" :)
PostPosted: Thu Dec 12, 2013 10:09 pm  (#4)
Very nicely done. :)
PostPosted: Fri Dec 13, 2013 8:58 am  (#5)
That worked out really well, Nice job.
PostPosted: Tue Dec 17, 2013 3:13 pm  (#6)
I've simplified the process a little. First step is to put a black layer under the frost, then change the frost layer to "Hard light"--that usually brings out the stars right away, and leaves better nebulas. Copy visible, paste as new layer, and start touch-ups from there.
Also works on sparkly snowbanks, like this dirty leftover April snow.
