It is currently Thu Nov 19, 2026 6:20 am
 Post subject: My feeble atempt at a transparent splash screen.
PostPosted: Sun Dec 15, 2013 5:39 am  (#1)
This splash should open over the desktop wallpaper exactly aligned as to look like only the green 3D Gimp-2.8 is loading. :) :bigthup
A test... I am a little off but i can live with that. The rest i can fix with the clone tool. :)
If you have this wallpaper on XP feel free to use the splash if you want.
 Post subject: Re: My feeble atempt at a transparent splash screen.
PostPosted: Sun Dec 15, 2013 6:15 am  (#2)
Cool idea..
PostPosted: Sun Dec 15, 2013 6:21 am  (#3)
ofnuts wrote:
Cool idea..
Thanks Ofnuts. I think i can probably use the Iwarp tool to fix the discrepancies. :)
PostPosted: Sun Dec 15, 2013 7:05 am  (#4)
Now i just need a transparent Windows XP theme. :)
PostPosted: Sun Dec 15, 2013 8:01 am  (#5)
Nice! :bigthup
PostPosted: Sun Dec 15, 2013 8:43 am  (#6)
rod: that's a really cool idea :)! i change wallpaper all the time, but maybe i could make a neutral sort of transparent gimp splash screen that would go with all of them? it's worth a try!
PostPosted: Sun Dec 15, 2013 11:53 am  (#7)
Great idea Rod!
PostPosted: Sun Dec 15, 2013 12:45 pm  (#8)
The tricky part is getting the correct area to copy on your screen. :)
PostPosted: Sun Dec 15, 2013 1:29 pm  (#9)
:wh
I thought that Gimp didn't support transparent backgrounds on it's splash screens. I've tried this before, and Gimp has always filled in the transparent areas with black.
I must be wrong about this , because obviously you've made it happen. ;)
How did you manage to get the background to remain transparent when opening Gimp? I've been wanting to do this for ages.
There's something fishy going on here... :hoh
PostPosted: Sun Dec 15, 2013 1:32 pm  (#10)
Great Idea Rod.
PostPosted: Sun Dec 15, 2013 3:28 pm  (#11)
I know how you did it Rod... :mrgreen:
PostPosted: Sun Dec 15, 2013 4:14 pm  (#12)
I know how you did it... :mrgreen:
Opacity of the background layer?
PostPosted: Sun Dec 15, 2013 7:57 pm  (#13)
Like I mentioned... Gimp doesn't support the transparency of PNG images used as a splash. Gimp will turn any transparent areas in a PNG splash image to, #000000.
So how do you think it was done? :mrgreen:
PostPosted: Sun Dec 15, 2013 8:01 pm  (#14)
Does it involve a masking colour?
PostPosted: Sun Dec 15, 2013 8:12 pm  (#15)
In a way yes, but not really. :hehe
PostPosted: Sun Dec 15, 2013 8:14 pm  (#16)
1. Take a screenshot of the desktop background.
2. Take a screenshot of the Gimp splashscreen loading, for reference.
3. Make Gimp splash screen using hidden desktop area.
PostPosted: Sun Dec 15, 2013 8:17 pm  (#17)
I think you would have to amend the GTK file as well
PostPosted: Sun Dec 15, 2013 8:28 pm  (#18)
Nope...
Exactly!
Your the big wiener, I mean winner Odin! :hehe
PS... There really wasn't anything to be won.
PostPosted: Sun Dec 15, 2013 9:38 pm  (#19)
Wallace and Odin figured it out. :)
But i did it the hard way. :lol
I used folders on my desktop as corner references for a snapshot area.
Using FastStone capture i selected that area and created the splash screen then added the 3D with "The GrassyVine PhotoFont" and 3D-Extrude. Of course i had to fix mine a wee bit to match but it works. I was really surprised my area was that close when it opened on my desktop the first time.
Pretty cool.
PostPosted: Sun Dec 15, 2013 9:58 pm  (#20)
No, it's not my dog.
