It is currently Fri Nov 20, 2026 3:28 pm
 Post subject: Some more op-art
PostPosted: Sun Dec 15, 2013 8:15 pm  (#1)
Using my favorite subject... This time the whole thing is scripted :)
 Post subject: Re: Some more op-art
PostPosted: Sun Dec 15, 2013 8:18 pm  (#2)
Nice one. How was it done?
PostPosted: Sun Dec 15, 2013 8:49 pm  (#3)
this is great, ofnuts !
my guess is you didnt use the method that pegleg showed here, did you ?
viewtopic.php?f=23&t=9266
i did something similar with Inkscapes tiled clones
its actually pretty easy once you have the settings right
but as IS is sometimes extremely un-intuitive, it took me a lot of trial and error to get the effect
PostPosted: Sun Dec 15, 2013 9:16 pm  (#4)
It's the method I explained there.
With the script, you just provide your image and a set of tiles of varying overall luminosity, as layers in another image, so your work is really finding interesting tiles and the adequate pre-processing of the main image.
PostPosted: Sun Dec 15, 2013 10:03 pm  (#5)
ah yes !
i actually played quite a lot with your technique but wasnt able to post the results because i used an image of a buddy of mine
does this mean i can hope for a script-release at some time in the (hopefully not so distant) future ? :)
PostPosted: Sun Dec 15, 2013 10:35 pm  (#6)
Ya that looks nice. I've never seen nice round dots like that. I hope there's a script release too.
Pegleg
PostPosted: Mon Dec 16, 2013 2:32 am  (#7)
@esper: yes, just giving it a bot of testing before release
@PegLeg44: the shapes aren't generated by the script. They are any shape your provide for the tiles.
PostPosted: Mon Dec 16, 2013 2:41 am  (#8)
ofnuts: oooh nice! i look forward to that script.
PostPosted: Mon Dec 16, 2013 3:43 am  (#9)
The famed horse head:
With disks (my current set of disks is a bit coarse for this):
With stripes (only 4 different stripe widths):
PostPosted: Mon Dec 16, 2013 6:57 am  (#10)
@Ofnuts
:jumpclap for HorseHead-Stripes.png
PostPosted: Mon Dec 16, 2013 8:49 am  (#11)
Same with tiny circles:
PostPosted: Mon Dec 16, 2013 10:04 am  (#12)
:clap :clap :clap cool looking forward for the script :jumpclap
PostPosted: Mon Dec 16, 2013 10:19 am  (#13)
ofnuts, really cool idea. Two years ago, I've added a 'Dots' filter in G'MIC, that is able to create things like your very first example. But today, you have made me realized that my filter was old and need some update. So here it is.
I've added a new filter Patterns / Shapes in the G'MIC plug-in for GIMP, that is strongly inspired by what ofnuts proposed in this thread. It looks like this :
And a zoom on the preview images :
You can select the shapes type (circles, squares, diamonds, horizontal or vertical stripes), and various parameters for the type of rendering. At the end, this is a quite versatile filter that can create lot of different effects.
Hope you'll enjoy it, and thanks again ofnuts for the great idea !
PostPosted: Mon Dec 16, 2013 11:30 am  (#14)
thanks for another great filter, Ronounours !!!!
wouldnt it be nicer if it was called Op-Art instead ?
thats a bit more intuitive than Shapes
just a suggestion
PostPosted: Mon Dec 16, 2013 11:34 am  (#15)
No problem, let call it 'Op art' if you want :)
I was not very happy with the filter name.
PostPosted: Mon Dec 16, 2013 11:58 am  (#16)
With my low-tech script you can use anything for the shapes:
PostPosted: Mon Dec 16, 2013 12:59 pm  (#17)
:coolthup
PostPosted: Wed Dec 18, 2013 10:49 pm  (#18)
Very very interesting, Ofnuts!
David, impressive at how quick you turn things around in GMIC - scripts to working GMIC functions.
PostPosted: Thu Dec 19, 2013 2:42 am  (#19)
Extremely cool Offnuts. Including my pattern set (just scaled it down to 10x10 for this render). Hope others will share their patterns too. :)
dot_pat.xcf [31.37 KiB]
Downloaded 98 times
PostPosted: Thu Dec 19, 2013 2:58 am  (#20)
Why not a truchet blend too (originally had to do this the hard way and too lazy to find the tut). Would be cool to try Wallace's pipes too but way too lazy to do so myself. Again, I scalled the pattern before applying it. :)
truchet.xcf [32.91 KiB]
Downloaded 93 times
