It is currently Fri Nov 20, 2026 3:28 pm
 Post subject: A Griderized effect
PostPosted: Sat Dec 21, 2013 3:22 am  (#1)
XCF workspace file attached.
Griderized-splash-gimp-2.8_RD.xcf [6.19 MiB]
Downloaded 91 times
 Post subject: Re: A Griderized effect
PostPosted: Sat Dec 21, 2013 5:12 am  (#2)
That looks cool Rod, can I add it to my splashes folder?
PostPosted: Sat Dec 21, 2013 5:15 am  (#3)
Be my guest. :)
PostPosted: Sat Dec 21, 2013 5:20 am  (#4)
Be my guest. :)
Okay great! :bigthup
BTW... I added a link so you can download the "pipe line" PHF file. The link is in the tread where you asked for the phf file, I think the thread is about gradients, but I can't remember.
PostPosted: Sat Dec 21, 2013 5:59 am  (#5)
Great result Rod :paint
The idea of ​​superimposing straight lines and curves is something poetic :)
PostPosted: Sat Dec 21, 2013 6:12 am  (#6)
Thank you Sam. :)
@ Wallace - Thanks! Now i must go find it again. :lol
EDIT: Found it! :bigthup
viewtopic.php?f=12&t=7864&start=50#p120945
Thanks again.
PostPosted: Sat Dec 21, 2013 6:57 am  (#7)
Thanks again.
Yes I see... Okay. :hi5
PostPosted: Sat Dec 21, 2013 8:15 am  (#8)
Really nice composition and creative use of lines & curves on this one, Rod. :2thup
PostPosted: Sat Dec 21, 2013 8:39 am  (#9)
Thank you very much Tux. :)
PostPosted: Sat Dec 21, 2013 10:16 am  (#10)
Nice one Rod.
PostPosted: Sat Dec 21, 2013 10:20 am  (#11)
Cool effect Rod
