It is currently Fri Nov 20, 2026 2:27 pm
 Post subject: 3D Snow
PostPosted: Sat Jan 18, 2014 4:10 am  (#1)
Thanks to Graechan (Snow Covered scm) and GnuTux (3D Extrusion scm) and GIMP devs for GIMP. :)
Both scripts available at GimpScripts.com :bigthup
Graechan i also added a shadow UNDER the snow topping layer.
I alpha to selected the snow topping layer, created a new layer and filled with black. Then dropped it under the snow topping layer.
Then i followed these three procedures on that new shadow layer..
Blurred by 17
Opacity set to about 56%.
Then i moved it down about 7 pixels.
Here is one i made from Graechans "Furry.scm" and GnuTux's "3D Extrusion.scm"
Both XCF Workspace Files attached below. :clap
3D-Snow.xcf [3.53 MiB]
Downloaded 140 times
Furry-GIMP-2.6-3D-Extrude.xcf [741.52 KiB]
Downloaded 135 times
 Post subject: Re: 3D Snow
PostPosted: Sat Jan 18, 2014 4:38 am  (#2)
The furry one looks so cool.
PostPosted: Sat Jan 18, 2014 4:56 am  (#3)
Both Furry and 3D Extrusion really compliment each other. :bigthup
Wondering if Graechan will add a "Furry Pillow" setting to the filter?
PostPosted: Sat Jan 18, 2014 11:30 am  (#4)
rod: cool use of those filters! i need to try that snow thing as soon as i can.
PostPosted: Sat Jan 18, 2014 3:12 pm  (#5)
Nice job combining scripts. Both results turned out well.
PostPosted: Sat Jan 18, 2014 7:59 pm  (#6)
Rod I'm impressed with the result you achieved combining Snow covered and 3D Extrusion the snow actually looks like it's hanging on the top of the text :bigthup
PostPosted: Sun Jan 19, 2014 8:28 am  (#7)
Thanks folks but all credit goes to you wonderful script writers. :)
