It is currently Fri Nov 20, 2026 2:29 pm
 Post subject: new work
PostPosted: Wed Jan 29, 2014 12:44 am  (#1)
I'm not sure how to finish this or where to go with it. but thought i would share what i had done.
 Post subject: Re: new work
PostPosted: Wed Jan 29, 2014 3:02 am  (#2)
Love it thus far.
I am assuming that is a rock bridge? I would (if I could) add some highlights and shadows either side to bring out the rock or trees if it is a path in the forest. (Am I close?)
PostPosted: Wed Jan 29, 2014 4:00 am  (#3)
It's looking good so far. Nice sky and atmosphere.
PostPosted: Wed Jan 29, 2014 4:24 am  (#4)
if I may make a suggestion:
put some "structure" (texture) on the front components (rock, path); even if "invisible" at a first look, it should appear applying some "detail extractor" plug-in...
PostPosted: Wed Jan 29, 2014 5:29 am  (#5)
sallyanne wrote:
Love it thus far.
to tell the truth i just started painting. had no idea before hand of what to do. it took about 20 minutes to do what you see. kinda think highlights are needed to. not sure if i can pull it off. :)
PostPosted: Wed Jan 29, 2014 5:30 am  (#6)
thanks
PostPosted: Wed Jan 29, 2014 1:35 pm  (#7)
On first sight I thought of an old Star Trek episode, the original series, where Kirk, Spock and all are standing beside a portal of some kind on a rocky, as usual, planet. The portal has more or less the same shape as in picture. Might be a direction to take the picture in.
I like the background and distant mountains, they both look good. But as others have said the foreground lacks detail and is the place that needs to be worked on. Good work so far though.
DeviantArt gallery
PostPosted: Wed Jan 29, 2014 2:40 pm  (#8)
This image would be a good place to try out the dodge and burn tool. You could experiment lighting and darkening the rocks to make them stand out. Just a thought, There is always the Undo button.
PostPosted: Wed Jan 29, 2014 5:05 pm  (#9)
thanks molly. i got it saved as a xcf file. will do more work this weekend. just having fun and ended up with this. more to come. i promise
PostPosted: Wed Jan 29, 2014 5:06 pm  (#10)
agree on the detail of the foreground.
