It is currently Fri Nov 20, 2026 2:27 pm
 Post subject: Simple logo
PostPosted: Thu Jan 30, 2014 5:27 am  (#1)
Created this for someone online.
Image I did a plain one
a embossed on.
Each one is made entirely in gimp from only 6 parts except the one with the circle. The guy wanted a Classic vintage camera look with the logo worked into it.
What do you think? Which one - if any would you choose?
 Post subject: Re: Simple logo
PostPosted: Thu Jan 30, 2014 5:37 am  (#2)
I like the first Logo. The bump mapping in the second looks a little rough in places and I'm wondering if it might be better to play with the bevel filter instead. I think the lens will need to have some depth as well if you are going to use it.
PostPosted: Thu Jan 30, 2014 5:58 am  (#3)
Thanks Erisian I think I know what went wrong in part of the bumped one. I will try the bevel filter instead.
PostPosted: Thu Jan 30, 2014 5:17 pm  (#4)
Thank you Conbagui
