It is currently Fri Nov 20, 2026 2:29 pm
 Post subject: Valentine Grunge
PostPosted: Wed Feb 05, 2014 2:04 am  (#1)
This image has come about mainly because I do like the grunge effect but hate having to use brushes, So I have been playing with the filters to see what effects I could achieve.
Just for interest but the broken outline around the heart and flower all came about by accident and is really simply to achieve,
1. Create your shape or text and select outline
2. On a new layer outline your shape
3. Run G'mic cubism filter on outline layer, the filter is located under the artistic folder.
The Text effect is fairly straight forward as well
Create>logo>particle trace>Text Size 60
Delete all layers apart from sparkle
Colours>Desaturate>Luminosity
Alpha select text
Ink tool>Select Diamond Shape
New Layer>lower layer
Colour Black>stroke selection>ink tool>emulate Brush
Select>None
Layer>merge down
Filters>Light & Shadow>Drop Shadow
Offset x -15, y -15, colour white
 Post subject: Re: Valentine Grunge
PostPosted: Wed Feb 05, 2014 8:01 am  (#2)
Very cool find he4rty.
PostPosted: Wed Feb 05, 2014 11:36 am  (#3)
very clever, and the effect is better than most brushes can make!
PostPosted: Wed Feb 05, 2014 11:40 am  (#4)
The text intrigues me.
Nice effects! :3
PostPosted: Wed Feb 05, 2014 11:42 am  (#5)
he4rty: :clap that's a really nice design and i love the grungy look. would be fun to know what other filters were involved apart from the g'mic cubism filter?
PostPosted: Wed Feb 05, 2014 1:14 pm  (#6)
Nice technique he4rty!
I remember I needed an effect like this but after a few tries in gimp gave up and did it in vector editor.
Now I know how :mrgreen: Thanks!
PostPosted: Wed Feb 05, 2014 2:53 pm  (#7)
Nice work he4rty
PostPosted: Thu Feb 06, 2014 1:18 am  (#8)
Thanks for the Comments, I've added a quick tutorial to the first post of how the text was achieved.
