It is currently Fri Nov 20, 2026 2:27 pm
 Post subject: cubism text fx
PostPosted: Sat Feb 08, 2014 12:05 pm  (#1)
attached xcf files are pretty much self explanatory
Cubism.xcf [2.29 MiB]
Downloaded 137 times
3D_mosaic1.xcf [1.37 MiB]
Downloaded 162 times
 Post subject: Re: cubism text fx
PostPosted: Sat Feb 08, 2014 12:42 pm  (#2)
this one wasn't made with gimp but fits the idea
PostPosted: Sat Feb 08, 2014 12:44 pm  (#3)
briliant idea
PostPosted: Sat Feb 08, 2014 7:18 pm  (#4)
k1tesseraena: nice text effects, brother :)! i will definitely try that out in g'mic! how did you make the last one, blender?
PostPosted: Sat Feb 08, 2014 8:05 pm  (#5)
Thank you conbagui, AnMal!
@AnMal Right, 2nd image - gmic's 3d extrusion. The only problem - the filter is very inconsistent in producing the same result from the same input image/layer.
The last image was made in Illustrator.
And this is how the 1st image is supposed to be looking when finished :mrgreen:
PostPosted: Sat Feb 08, 2014 11:37 pm  (#6)
Lovely results.
PostPosted: Sat Feb 08, 2014 11:39 pm  (#7)
Those would make excellent PhotoFonts. :)
PostPosted: Sun Feb 09, 2014 9:00 pm  (#8)
cant stop messing with ai script that I discovered yesterday :mrgreen:
btw, I guess that's what I meant in GnuTux's 3D Extrusion script thread viewtopic.php?f=9&t=9273&start=10#p121376
K1TesseraEna wrote:
For the b/w images it would be great to have as an option the extrusion based on image's height(depth) map.
Although, without it I get an interesting effect too.
PostPosted: Mon Feb 10, 2014 4:52 am  (#9)
Nice results, tried doing something similar but manually and failed, so would be interested in what this ai script is you are talking about.
PostPosted: Mon Feb 10, 2014 5:00 am  (#10)
k1tesseraena: that's really cool! not a fan of adobe products, but i almost changed my mind :).
PostPosted: Mon Feb 10, 2014 12:11 pm  (#11)
k1tesseraena: why not using the G'MIC plug-in for doing this kind of thing ? :)
(well, I'm cheating, I've just added the filter few minutes ago).
Let me know if you think it's interesting !
After a filter update, there is what you should be able to see (requires version 1.5.8.0+ of the plug-in).
The cool thing with this filter is that it creates a transparent image, so you can easily add shadow or other effects on it before putting a background, like this :
How is that ? :sleepkbd
PostPosted: Mon Feb 10, 2014 12:50 pm  (#12)
Another simple example, created from scratch ('Create from logo'), applied 3d blocks filter, then added some light effects.
PostPosted: Mon Feb 10, 2014 12:53 pm  (#13)
wow, just wow David!
You are a magician! I like your gmic filter even better than Illustrator's.
More controls like tilt, fov, size etc.
Thanks a lot for the new filter!!!
BTW here's the Isometric Block Raster script window. It has the light control settings.
But lacks other features that your filter has.
PostPosted: Mon Feb 10, 2014 1:01 pm  (#14)
I will try to add more controls in the future, like something to control the smoothness of the elevation map, and probably the position of the light source too.
PostPosted: Mon Feb 10, 2014 1:03 pm  (#15)
Thank you, David! I think your new filter deserves a separate thread so more ppl will be aware of the update.
This filter is awesome!
PostPosted: Tue Feb 11, 2014 12:12 am  (#16)
New thread in G'MIC Discussions for 3d blocks.
Subject: G'MIC | Rendering | 3d blocks
