It is currently Fri Nov 20, 2026 2:28 pm
 Post subject: ~
PostPosted: Sat Feb 15, 2014 9:38 pm  (#1)
 Post subject: Re: Self-Righteous of Justice that Justify the Path to Victory
PostPosted: Sat Feb 15, 2014 9:51 pm  (#2)
Very good result easily the best line art I've seen done in gimp
 Post subject: ~
PostPosted: Sat Feb 15, 2014 10:47 pm  (#3)
PostPosted: Sun Feb 16, 2014 6:42 am  (#4)
Flat coloring... :roll:
Real coloring, not sure what it called, never attend art school...
What the background should be? Hrrr...
Lava lava lava burn burn burn!!!
Here is the lava tutorial, BTW:
1. Fill the background with black-but a little red in it, or color pick example picture (No.1).
2. Use the TEXTURE_HOSE brush, default in Gimp 2.8.
3. Change the brush mode to ADDITION.
4. Change opacity to 40-50. If you are using mouse, set it lower, about 10-20...
5. Use red but a little black as color, or color pick from example (No.2)...
6. Paint it on the background, do it several times... :)
7. Change the color to orange, or color pick from the example (No.3)...
8. Paint above result of step no. 6...
9. Ta-da!
PostPosted: Sun Feb 16, 2014 7:14 am  (#5)
Your work is fantastic Zeo. You are one talented guy.
PostPosted: Mon Feb 17, 2014 12:39 pm  (#6)
Oh thanks thanks thanks thanks :cry
So here is the final result, just adjust the color a little bit from the previous screenshoot... :faint
:otb :otb :otb
PostPosted: Mon Feb 17, 2014 12:55 pm  (#7)
Seriously good work. I would say you're in the same league as any of the comic illustrators I've seen, or the folks who do the animations in movies.
DeviantArt gallery
