It is currently Thu Nov 19, 2026 9:18 am
 Post subject: The new text art filter
PostPosted: Thu Jan 13, 2011 2:07 pm  (#1)
Looks kinda cool. :)
 Post subject: Re: The new text art filter
PostPosted: Thu Jan 13, 2011 10:23 pm  (#2)
very cool...is it a script?
PostPosted: Thu Jan 13, 2011 11:56 pm  (#3)
I think its this: http://registry.gimp.org/node/24974
PostPosted: Fri Jan 14, 2011 7:01 am  (#4)
Yeah its a new script from this site
http://simply-signage.com/blog/?p=89
PostPosted: Mon Jan 17, 2011 4:05 am  (#5)
I've put the file in C/Program Files/GIMP-2.0/lib/gimp/2.0/plug-ins. I opened up GIMP but i can't find it.
Should I put the .py file in the Python folder? Where do I find this tool in GIMP?
PostPosted: Mon Jan 17, 2011 4:16 am  (#6)
I don't recommend people putting scripts and plug-ins in their application folders in Program Files, because when you upgrade or delete GIMP, you'll lose them. Put plug-ins and scripts in your C:\Users\username\.gimp-2.6\plug-ins and scripts folders instead.
Python files are considered "plug-ins" so they will go in the plug-ins folder.
Scripts have the .scm extension and go in the scripts folder. (the only thing that will go in this folder is .scm files)
Once you have it correctly installed, you'll find it under File/Create/Web Page Themes/www.bytes-and-pixels.com on the menu.
PostPosted: Mon Jan 17, 2011 7:58 am  (#7)
If you can not see it after following Mahvins explanation.You probably need python installed.
Python is needed and if you install it, you must re-install Gimp to use python-fu.
There is a tutorial just for this on the gimpuser site which contains all instructions for installing it.
http://www.gimpusers.com/tutorials/inst ... -6-windows
PostPosted: Mon Jan 17, 2011 4:11 pm  (#8)
I can see the Filters-->Python-->Console menu selection so I'm pretty certain I installed Python correctly using that tutorial.
PostPosted: Tue Jan 18, 2011 12:48 am  (#9)
OK I can see this in the menu, but when I select Word Art nothing happens, even if I hace created a text layer???
This is the file I have in my plug-ins folder: b&p_word_art_01_v1.0.py
PostPosted: Tue Jan 18, 2011 1:36 am  (#10)
You don't need to create any layers, or open any images. You should be able to call it directly, and it creates it's own image. You'll need to get support from the plug-in developer, try either leaving a comment on the Registry or see if he has an email address on his website.
PostPosted: Tue Jan 18, 2011 5:01 am  (#11)
As Mahvin said, you just need to select the plug-in and then select all your values for the artwork.The plug-in creates a new document, hence the reason it is found under create/new
It is also possible you need to unblock the exe file.
In windows XP right click the file select properties/unblock/apply/ok
In Linux, and Mac i am not sure how to chmod them.
PostPosted: Tue Jan 18, 2011 2:53 pm  (#12)
I did look at the properties of the file but I couldn't see any unblock option. I am using Windows 7. The developer did reply to me on the B&P website. I also left a comment on the GIMP registry website but I'm still waiting for it to be approved so people can see it.
PostPosted: Tue Jan 18, 2011 3:51 pm  (#13)
Hmmm. The author says it's using a hacked gimpfu module, so I wonder what other filter it can break when installed...
PostPosted: Thu Jan 20, 2011 5:36 am  (#14)
It works well on windows xp, could be it just isn't compatible with windows 7.
PostPosted: Thu Jan 20, 2011 1:35 pm  (#15)
That's what the developer suggested before I told him I was on Windows 7. I've posted comments on the GIMP registry for this script days ago and I'm still waiting for the moderators to approve them. Very frustrating on all counts.
PostPosted: Thu Jan 20, 2011 1:43 pm  (#16)
have you registered to the gimp repository?
then all you need to do is log-in and post a comment.
PostPosted: Thu Jan 20, 2011 2:14 pm  (#17)
Yup. But then it says your comment has been saved and is waiting approval from the moderators.
PostPosted: Thu Jan 20, 2011 2:20 pm  (#18)
I see your comments as being posted on the Registry, AeonTown. I just checked.
PostPosted: Thu Jan 20, 2011 8:21 pm  (#19)
I must be blind. I can't see them.
PostPosted: Thu Jan 20, 2011 8:34 pm  (#20)
Comments
January 20, 2011 - 00:14 — AeonTown
Plugin not working
Hi
I can see the Word Art option in the File-Create menu, but when I click it, nothing happens. Can you help please?
I am using Windows 7. GIMP Version 2.6.10. Python 2.6.6.
delete edit reply report to Mollom not spam (1) mark as spam
January 17, 2011 - 00:56 — AeonTown
Plug-in
I have put this file in the Plug-in folder and opened GIMP but I can't see this feature. Where do I find it in GIMP?
January 16, 2011 - 12:52 — seniorgimper
Now i did......
I right-clicked and checked the box.....................It works!!!!
Many Thanks!
delete
Check your email, I just resent your validation email. Also, check your spam folder for it, if it doesn't show in your inbox with regular email.
