It is currently Tue Nov 17, 2026 4:05 am
 Post subject: Hatch or Hachure Text
PostPosted: Mon Apr 07, 2014 10:03 am  (#1)
Hi, I need some help. I have been playing with fonts and text and want to create some text with Hatched or Hachure (I think that is correct) inside the font. The process itself is not difficult. Select a suitable "fat" font, enlarge it, font to selection, Cut, stroke the selection. On a new layer copy the selection, shrink the selection and fill with a hatched pattern or brush.
This is where I would like some help with the pattern or brush. Vertical and Horizontal hachures brushes and patterns are easy to make with the pattern/grid generator.
To make a visually appealing "tilted" hachure pattern or brush is quite difficult. I find that even with a 45 degree rotation there are "nicks" in the lines. Personally, I like a tilt of around 22.5 , 25 -30 degrees. I have played for hours with the grid filter and rotating as well as the newsprint filter in line mode. Can anybody give me some other method or supply a nice brush (one that takes colour) ? Image
I attach some brushes and pattern to give some idea (hope I have attached the correct brush and Pattern. I have made bigger brushes but they are over 1.5 Mb so I did not include them
my diagonalrush19.gih [468.92 KiB]
Downloaded 304 times
mypattern7.pat [68.17 KiB]
Downloaded 269 times
 Post subject: Re: Hatch or Hachure Text
PostPosted: Mon Apr 07, 2014 10:21 am  (#2)
You can compress them with zip or 7z, and upload the compressed file
PostPosted: Mon Apr 07, 2014 10:31 am  (#3)
wbool63, that looks really nice; like the effect. Have downloaded - thank you so much for sharing.
McGimp 2.8.14
G'mic 1.6.5
PostPosted: Mon Apr 07, 2014 11:09 am  (#4)
Thank you Wooble for the nice pattern and brush.
PostPosted: Mon Apr 07, 2014 12:12 pm  (#5)
wbool63 wrote:
... Select a suitable "fat" font, enlarge it, font to selection, Cut, stroke the selection.
You would obtain a cleaner result if you do "Text to Path" and stroke the path.
Probably not what you're seeking, but perhaps the following technique would be worth playing around with.
In the Blend Tool's Options dialog, choose the "FG to BG (Hardedge)" gradient and set the Repeat to either "Sawtooth" or "Triangle".
You can now draw on the canvas to create your hachure pattern. The length of your stroke determines the spacing of the lines. You can hold down the CTRL key to constrain the angles to 0, 22.5, 30, 45, et cetera. Turn on Supersampling to achieve a more natural appearance.
With a little experimenting, one can achieve fairly decent results.
PostPosted: Mon Apr 07, 2014 1:17 pm  (#6)
Have a look at 10 GIMP PATTERN by graphicavita. They are very handy not only for the pattern, they are semi-transparent. In Gimp the Stripes and Stripes Fine patterns work in a similar way.
PostPosted: Mon Apr 07, 2014 7:12 pm  (#7)
Thank You Saulgoode, I will certainly try to use your method of creating tilted parallel lines. It is exactly what I am looking for. I agree that stroking the path yields a better outline, but yesterday my concern was with the hatch!
@ Odin , Thank you for that link , I will have a closer look at that.
@ Keshef, Dalia and Molly , thank you for your replies
When I get it sorted out, I will make a small tut on this text method.
PostPosted: Tue Apr 08, 2014 11:03 am  (#8)
Hi, I have made a new set of brushes that take colour. I have made a few new texts with hatch or hachure.
This hatching method of fonts adds some interests to headings or sub headings (eg in Map titles) Here is one example using a somewhat "fat" font, using one colour only.
I include some reasonably believable hachure / hatch brushes.
30tilt2.gbr [87.93 KiB]
Downloaded 237 times
mybrush6.gbr [9.81 KiB]
Downloaded 235 times
mybrush5.gbr [87.93 KiB]
Downloaded 233 times
I hope I have attached the correct brushes, I have a problem understanding the brush naming convention.
I will do a a tut of this method in a day or so, I am pretty strapped for time for a day or so.
PostPosted: Tue Apr 08, 2014 11:12 am  (#9)
30tilt2.gbr
mybrush6.gbr
mybrush5.gbr
I think it loos great. :jumpclap
How you used these brushes would be interesting to see in your tutorial. I'm looking forward to it. ;)
