It is currently Mon Nov 23, 2026 12:34 pm
 Post subject: Free/Open source Futura font(s)
PostPosted: Tue Apr 08, 2014 6:56 am  (#1)
Is there such a thing? The font design itself is in the public domain.
 Post subject: Re: Free/Open source Futura font(s)
PostPosted: Tue Apr 08, 2014 7:23 am  (#2)
ofnuts, I can't understand your question.
PostPosted: Tue Apr 08, 2014 8:18 am  (#3)
In short, I'm looking for free fonts in the Futura family.
PostPosted: Tue Apr 08, 2014 8:34 am  (#4)
I just got some futura fonts from Google, http://www.1001fonts.com/futura-fonts.html
PostPosted: Tue Apr 08, 2014 8:49 am  (#5)
Close but no cigar... I'm looking for the one true Futura font and usual derivatives (Condensed, Black, Bold...)
PostPosted: Tue Apr 08, 2014 9:01 am  (#6)
I guess I just don't understand exactly what you are looking for.
http://www.1001freefonts.com/ventura.font
PostPosted: Tue Apr 08, 2014 9:07 am  (#7)
These fonts: http://www.myfonts.com/fonts/urw/futura/
PostPosted: Tue Apr 08, 2014 9:14 am  (#8)
Is this one?
Futura.7z [17.52 KiB]
Downloaded 1368 times
PostPosted: Tue Apr 08, 2014 9:27 am  (#9)
Anything here that might work for you?
http://fonts.goldenweb.it/index_file/l/ ... fault.html
that is as close as I can get with the url, do a futura search when you get there
PostPosted: Tue Apr 08, 2014 10:58 am  (#10)
Is this one?
One of them :) Thx.
PostPosted: Tue Apr 08, 2014 11:00 am  (#11)
Wonderful. Just what the doctor ordered.
PostPosted: Tue Apr 08, 2014 12:17 pm  (#12)
Do you want some more ofnuts?
futura fonts.7z [191.44 KiB]
Downloaded 432 times
PostPosted: Tue Apr 08, 2014 1:47 pm  (#13)
The whole set... Hmm. Thx.
PostPosted: Tue Apr 08, 2014 2:10 pm  (#14)
yup, as many free ones I could find.
PostPosted: Fri Apr 11, 2014 3:32 pm  (#15)
Got licensing info on those?
Tony
mechatherium.deviantart.com
What did you expect? Shakespeare?
PostPosted: Thu Jun 12, 2014 5:36 am  (#16)
I think it requires you to pay around $20 bucks to use it. But its weird since the fonts are dated 30' but it had a debut by 2000?
How can you be sure those are free/open source and a lot of fonts look a like so whats the major difference?
PostPosted: Thu Jun 12, 2014 6:56 am  (#17)
Licensing of fonts is a very tricky subject. In some countries, the design and name are protected, and in others only a specific implementation is (so you can do an exact clone and get away with it, and in some countries you can even sell it under the original name).
PostPosted: Fri Jun 13, 2014 2:39 am  (#18)
I do too, and thanks Molly. ;)
PostPosted: Mon Sep 01, 2014 6:59 am  (#19)
here is an example of a complain: google for "github dmca 2014-08-27 Monotype-Imaging"
(open source =! free ware) can be true - sometimes open source is very expensive aswell :)
