It is currently Mon Nov 16, 2026 10:31 pm
 Post subject: Environment Map Sharing Thread (Flat)
PostPosted: Mon Jun 30, 2014 6:37 pm  (#1)
Here are a few non-spherical (flat) emaps for use with GIMP's Lighting Effects Filter and/or the EnviroLogo Script.
Note: This type of EnvMap must NOT include an alpha channel or it won't work in the GIMP's LE filter.
File comment: Environment Maps For GIMP's Lighting Effects Filter
envmaps-flat.zip [1.69 MiB]
Downloaded 1462 times
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
 Post subject: Re: Environment Map Sharing Thread (Flat)
PostPosted: Mon Jun 30, 2014 6:44 pm  (#2)
Thank you very much Tux. They are all very interesting and should make some very nice text.
PostPosted: Mon Jun 30, 2014 6:48 pm  (#3)
Thanks Molly. I usually just generate EnvMaps on the fly from gradients but when I get one I like, I save it off. That's where most of these came from.
PostPosted: Mon Jun 30, 2014 8:57 pm  (#4)
What is the difference of using the flat vs the round enviro maps? I do not remember the why of it all.
PostPosted: Mon Jun 30, 2014 9:28 pm  (#5)
GIMP's lighting filter, along with the EnviroLogo Script, normally uses flat Environment Maps, with a requirement that those maps have no alpha channel.
The ML Bevel Reflect Plug-in, along with the BRL Script, normally uses spherical Environment Maps. Bevel Reflect maps normally contain an alpha channel, but it is not a requirement. With Bevel Reflect, the pixel in the upper left corner of the Environment Map determines the background color (or transparency) of the result.
Actually, GIMP's lighting filter and Bevel Reflect Logo can use any shape or size Environment Map, albeit, with varying results. It seems the best results can be achieved by using flat Environment Maps with GIMP's LE filter and spherical Environment Maps with Bevel Reflect.
PostPosted: Mon Jun 30, 2014 10:12 pm  (#6)
Thanks for the explanation, now all I need is to have the scrolling script for Mac and I will be all set!
