It is currently Tue Nov 17, 2026 4:35 am
 Post subject: Transparent Environment Maps
PostPosted: Sat Jul 05, 2014 5:15 pm  (#1)
I made some transparent emaps some time ago, to see what they would do. Here's some of the results, using the Bevel Reflect Logo script. I don't know that there's any great benefit to using them, other than it does leave a nice, crisp outline.
Using this map:
The result is this:
Nothing spectacular per se, but when you click on the eye to reveal the "BR Logo Copy" layer, which of course is black, it looks like this:
Other examples:
I'm adding the transparent emaps, if you want to give them a try. Thanks for looking.
Transparent Emaps.7z [1.35 MiB]
Downloaded 365 times
 Post subject: Re: Transparent Environment Maps
PostPosted: Sat Jul 05, 2014 7:06 pm  (#2)
That's such a cool idea. :jumpclap Thanks for posting these.
PostPosted: Sat Jul 05, 2014 7:10 pm  (#3)
Very nice Warrior, my fave is the second from bottom with the pretty greens, pinks and even a touch of yellow and orange. cool What is the font you used? I have one something like that but not sure.
PostPosted: Sat Jul 05, 2014 7:57 pm  (#4)
Thanks gang, they're fun to do. Molly, the font is called Black Letter.
PostPosted: Sat Jul 05, 2014 9:17 pm  (#5)
I never realized that the result from BRL was so much improved with the 'BR Logo Copy layer' set to visible
As I believe the scripts author does visit the site maybe he will update the script or tell us why it was left invisible
:mrgreen:
PostPosted: Sun Jul 06, 2014 1:06 am  (#6)
I like the results. The target image becomes transparent wherever the emap is transparent, an effect that could definitely be an advantage. :cool
Graechan wrote:
I never realized that the result from BRL was so much improved with the 'BR Logo Copy layer' set to visible. As I believe the scripts author does visit the site maybe he will update the script or tell us why it was left invisible :mrgreen:
In the BRL script, I make a copy of the original image for several reasons. It's not always advantageous to have the copied layer visible. In this post, I mentioned using the copied layer to create a smooth stroke or to blend the copy into the BRL result. This can helps to mitigate aliasing that can occur when the plug-in is called. When running from the alpha menu, I keep a copy to allow quick painting. You always have a copy of the original on which to make the next selection to be "painted".
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
PostPosted: Sun Jul 06, 2014 1:16 am  (#7)
thanks for the info GnuTux and sorry about the pun in my previous post
also elfnor claims to have posted a plugin to GimpScripts but I cannot find it there and I am having difficulty finding the menu location for the the (Multititle like) python plugin
PostPosted: Sun Jul 06, 2014 1:26 am  (#8)
You can also see this in the post I linked to above...
Use copy layer for blending
Use copy layer for a stroke
It's up now.
http://gimpscripts.com/2014/07/symmetry-tile/
PostPosted: Sun Jul 06, 2014 2:22 am  (#9)
Thank You GnuTux for the link
PostPosted: Sun Jul 06, 2014 11:34 am  (#10)
That's what I always use the BR Logo Copy layer for, cleaning up the edges. I usually alpha to selection the BR Logo Copy layer, invert it, go to the BRL Logo layer, and hit edit>clear. Works very well.
