It is currently Tue Nov 17, 2026 4:24 am
 Post subject: A Different Kind Of Emap
PostPosted: Fri Feb 27, 2015 8:03 pm  (#1)
I was experimenting the other night, making some new maps. Instead of mapping to sphere, or using the environment map script, I used this approach. Interesting results.
I took an image I found on the web:
Gave it a gaussian blur of 30, then cut out a circle, and saved it as a png:
This is the result of that map:
Here's some other results, using the same font.
It doesn't have to be a colorful image, it can be a simple photo:
If you give it less of a blur, it will be more textured. Sometimes that works okay with a larger, more rounded font. Lots of possibilities with this technique. Let's see what you got. :bigthup
 Post subject: Re: A Different Kind Of Emap
PostPosted: Fri Feb 27, 2015 9:18 pm  (#2)
Interesting results The Warrior; I'm partial to 3 & 5.
PostPosted: Fri Feb 27, 2015 9:31 pm  (#3)
Thanks, appreciate it.
PostPosted: Fri Feb 27, 2015 9:35 pm  (#4)
Very cool!
I've always found that by bluing an E-Map, it more often then not looks much better when used with BRL.
PostPosted: Fri Feb 27, 2015 11:56 pm  (#5)
Very cool!
Thanks Wallace. This is the technique I used for the iridescent font the other night.
PostPosted: Sat Feb 28, 2015 1:57 am  (#6)
How clever. Love the results :).
Margaret McGaffey Fisk
steampunk, fantasy, science fiction, and romance author
Tales to Tide You Over
PostPosted: Sat Feb 28, 2015 8:23 am  (#7)
Thanks! It's fun to blur any old photo, and see what the results will be.
PostPosted: Sat Feb 28, 2015 9:39 am  (#8)
A few more results.
PostPosted: Sat Feb 28, 2015 9:47 am  (#9)
great job Warrior! I have to try
PostPosted: Sat Feb 28, 2015 9:56 am  (#10)
How nice is it! Warrior. Thank you so much for sharing it with us all. :tyspin :coolthup
PostPosted: Sat Feb 28, 2015 10:14 am  (#11)
What a simple and effective way to deal with emapped images. :jumpclap
You could skip the circular cutout step and just cut/set the pixel(s) in the upper left corner to transparent.
Rather than just blurring a pattern fill or image, you could use some form of smoothing (G'MIC?) to produce an interesting result, which is what I've done in the past.
By the way, there is a blur final emap option in BRL. It's used when the emap is generated from a gradient.
"If Microsoft ever does applications for Linux it means I've won." - Linus Torvalds
PostPosted: Sat Feb 28, 2015 10:19 am  (#12)
:jumpclap Eureka!!
map (from a fractal FE)
result
PostPosted: Sat Feb 28, 2015 11:16 am  (#13)
Cool results gang. Endless possibilities.
PostPosted: Sat Feb 28, 2015 11:24 am  (#14)
Yes this is what I do too Tux, I have a folder full of flat emaps with the corner cut out. I have some really nice shiny ones in there too.
PostPosted: Sat Feb 28, 2015 11:24 am  (#15)
PostPosted: Sat Feb 28, 2015 11:40 am  (#16)
another Image
PostPosted: Sat Feb 28, 2015 11:42 am  (#17)
Molly, so nice your too. Lovely maps! :clap :bump
PostPosted: Sat Feb 28, 2015 11:50 am  (#18)
Thanks Issabella, I didn't make the map, I just downloaded the one Tux posted from above and made it into a flat map and added a bit of SuperNova to it.
PostPosted: Sat Feb 28, 2015 12:19 pm  (#19)
Here's some different ones I made that many will produce an iridescent effect. Some were ones I just found, and did nothing to.
New Maps.7z [3.05 MiB]
Downloaded 205 times
PostPosted: Sat Feb 28, 2015 12:21 pm  (#20)
Cool!
Thanks Warrior. :bigthup
