It is currently Tue Nov 17, 2026 2:53 am
 Post subject: FREE Halloween Vector Icons, color and B/W Sets
PostPosted: Thu Oct 06, 2016 9:10 am  (#1)
If you like making Halloween invites and such, here are some FREE vector icons, grab 'em while they are still SPOOKY!
Sorry,
but the provided link below,
is no longer available.
http://freedesignresources.net/free-halloween-vector-icons/
File comment: Original Halloween icon pack zip folder
halloween-icon-pack_aomam_141019.zip [1.89 MiB]
Downloaded 176 times
 Post subject: Re: FREE Halloween Vector Icons, color and B/W Sets
PostPosted: Thu Oct 06, 2016 11:00 am  (#2)
Hey they look pretty cool Mahvin - thanks for sharing :).
PostPosted: Thu Oct 06, 2016 12:22 pm  (#3)
Thanks for sharing!
PostPosted: Thu Oct 06, 2016 12:36 pm  (#4)
Mahvin, these are .ai files. Are they usable in Gimp?
PostPosted: Thu Oct 06, 2016 3:12 pm  (#5)
Pat, You just select "All files" instead of "All images" and select the .ai file.
open.
And an Import from PDF window will open up
and you can select both the color and lined and click on "Import"
and then it'll open them up as layers in GIMP.
PostPosted: Thu Oct 06, 2016 3:51 pm  (#6)
open.
Thanks for the tip, Trandoductin. I try to open .ai files in Inkscape but didn't realise they would open in Gimp.
PostPosted: Thu Oct 06, 2016 7:24 pm  (#7)
What Tin said! Yes, I forgot that some people may not be aware that ai files can be opened in GIMP, thanks for sharing that, Tin!
PostPosted: Thu Oct 06, 2016 8:23 pm  (#8)
Thanks for sharing, mahvin!
PostPosted: Wed Oct 12, 2016 12:49 pm  (#9)
The icons were so clear and nice, I made a Gimp animated brush from them. I've attached a zipped folder with halloween.gih in it to be put in your Gimp brushes folder.
Halloween Icons Brushes.zip [74.65 KiB]
Downloaded 307 times
PostPosted: Wed Oct 12, 2016 4:24 pm  (#10)
Thank you very much, Oregonian. So nice of you to share with us.
PostPosted: Wed Oct 12, 2016 4:29 pm  (#11)
You're welcome, Pat625. Nice poster! I love the lettering on it. A very nice font with a nice treatment.
:clap
PostPosted: Wed Oct 12, 2016 6:10 pm  (#12)
Cool beans!
PostPosted: Wed Oct 12, 2016 6:47 pm  (#13)
Thanks again, Oregonian. The lettering is from a custom font posted here in GimpChat using Tran's script. Font by Hardy111.
viewtopic.php?f=9&t=14696&start=10
PostPosted: Sun Feb 09, 2020 6:23 am  (#14)
There are lots of halloween clipart here
creazilla . com
PostPosted: Sun Feb 09, 2020 6:48 am  (#15)
Thanks
for the Halloween Icons Brushes
I like it :yes :yes :yes
Doron
