It is currently Wed Oct 07, 2026 6:49 pm
 Post subject: Convert adobe grd (gradient) to gimp
PostPosted: Fri May 20, 2011 7:27 pm  (#1)
Is it possible for someone with Swatchbooker possibly convert these adobe gradients to a gimp gradient for me.
Realistic Sky Gradients.zip [3.42 KiB]
Downloaded 372 times
 Post subject: Re: Convert adobe grd (gradient) to gimp
PostPosted: Fri May 20, 2011 9:42 pm  (#2)
Adobe GRD doesn't seem to be supported.
Unless i am doing something wrong?
PostPosted: Fri May 20, 2011 9:48 pm  (#3)
I could open them in PhotoShop and save as a image then i think i can turn them into Gimp GGR files from there.
These are the supported files
Reads color swatches from:
* Adobe aco, acb, act, ase, acf, bcf, clr
* AutoCAD acb (unencrypted only!)
* ColorSchemer cs
* Corel cpl, xml (X5)
* GIMP gpl
* ICC named colors profiles
* OpenOffice.org soc
* QuarkXPress qcl (+cui)
* RAL bcs
* RIFF pal
* Scribus xml
* VivaDesigner xml
* Xara jcw
PostPosted: Fri May 20, 2011 11:47 pm  (#4)
Here you go zip attached with gradients and xcf sample file.
Enjoy! :)
Gradients_Real-Sky_GIMP.zip [249.72 KiB]
Downloaded 1622 times
PostPosted: Sat May 21, 2011 6:40 am  (#5)
Your the man Rod. I see I was not the only one having a problem with opening them in Swatchbook. On the website it says
Reads gradient swatches from:
Adobe grd, clr
GIMP ggr
OpenOffice.org sog
Scribus xml
but as you too found out it does not seem to work. Thank you for taking the time to convert the gradients
PostPosted: Sat May 21, 2011 7:46 pm  (#6)
Not a problem, you are very welcome.
PostPosted: Sat May 21, 2011 7:51 pm  (#7)
Did you know you can create SVG gradients for Gimp and Gimp will run them?
I have a tutorial for it here Gimp SVG Gradient Tutorial if you are interested.Its much quicker than using Gimps gradient editor.
PostPosted: Sat May 21, 2011 8:32 pm  (#8)
Okay i had an awesome idea on converting Adobe gradients into Gimp gradients (html or text)
Here is an image of an Adobe Real-Sky gradient ran through the image-table-creator on my website.
One of the images is the real PNG image one is a table of hex colors.
Can you guess which is which? :)
Pretty far out - means you can take any example gradient image from Adobe and run it through this program.The results will be the hex colors you need to reproduce the gradient.
You will of course need to open one of your GRD files in a text editor and change the colors to the ones in the table produced.
The code needs to be tweaked though as it takes EVERY hex color into consideration, which means lines and lines of almost identical color codes.So many hex colors just for that one small gradient image that it has over 60,000 characters. :lol.In other words i couldn't post an example here.
Well here is a very small part of it.
<td width="1" height="1" bgcolor="#febe76"></td>
<td width="1" height="1" bgcolor="#febe75"></td>
<td width="1" height="1" bgcolor="#febd74"></td>
<td width="1" height="1" bgcolor="#febc72"></td>
<td width="1" height="1" bgcolor="#febb70"></td>
<td width="1" height="1" bgcolor="#feba6e"></td>
<td width="1" height="1" bgcolor="#feb96d"></td>
<td width="1" height="1" bgcolor="#feb86c"></td>
<td width="1" height="1" bgcolor="#feb86b"></td>
<td width="1" height="1" bgcolor="#feb769"></td>
<td width="1" height="1" bgcolor="#feb667"></td>
<td width="1" height="1" bgcolor="#feb566"></td>
<td width="1" height="1" bgcolor="#feb666"></td>
<td width="1" height="1" bgcolor="#feb665"></td>
<td width="1" height="1" bgcolor="#feb564"></td>
<td width="1" height="1" bgcolor="#feb562"></td>
<td width="1" height="1" bgcolor="#feb461"></td>
<td width="1" height="1" bgcolor="#feb560"></td>
<td width="1" height="1" bgcolor="#feb45f"></td>
<td width="1" height="1" bgcolor="#feb45e"></td>
<td width="1" height="1" bgcolor="#fdb35d"></td>
<td width="1" height="1" bgcolor="#fcb25b"></td>
<td width="1" height="1" bgcolor="#fdb25a"></td>
<td width="1" height="1" bgcolor="#fdb159"></td>
<td width="1" height="1" bgcolor="#fdb158"></td>
<td width="1" height="1" bgcolor="#fcaf57"></td>
<td width="1" height="1" bgcolor="#fdaf56"></td>
<td width="1" height="1" bgcolor="#fcad54"></td>
<td width="1" height="1" bgcolor="#fcab53"></td>
<td width="1" height="1" bgcolor="#fca951"></td>
<td width="1" height="1" bgcolor="#fca74f"></td>
<td width="1" height="1" bgcolor="#fca54e"></td>
<td width="1" height="1" bgcolor="#fca44d"></td>
<td width="1" height="1" bgcolor="#fca24d"></td>
<td width="1" height="1" bgcolor="#fca14c"></td>
<td width="1" height="1" bgcolor="#fc9f4b"></td>
<td width="1" height="1" bgcolor="#fc9d4b"></td>
<td width="1" height="1" bgcolor="#fc9b4a"></td>
<td width="1" height="1" bgcolor="#fc994a"></td>
<td width="1" height="1" bgcolor="#fc9649"></td>
<td width="1" height="1" bgcolor="#fc934a"></td>
<td width="1" height="1" bgcolor="#fc8f49"></td>
<td width="1" height="1" bgcolor="#fc8d48"></td>
<td width="1" height="1" bgcolor="#fc8948"></td>
<td width="1" height="1" bgcolor="#fc8647"></td>
<td width="1" height="1" bgcolor="#fc8347"></td>
<td width="1" height="1" bgcolor="#fc8046"></td>
</tr>
<tr>
<td width="1" height="1" bgcolor="#8e99be"></td>
<td width="1" height="1" bgcolor="#909bc1"></td>
<td width="1" height="1" bgcolor="#919dc3"></td>
<td width="1" height="1" bgcolor="#929ec4"></td>
<td width="1" height="1" bgcolor="#939ec5"></td>
<td width="1" height="1" bgcolor="#949fc6"></td>
<td width="1" height="1" bgcolor="#94a0c7"></td>
<td width="1" height="1" bgcolor="#95a1c8"></td>
<td width="1" height="1" bgcolor="#96a2c9"></td>
<td width="1" height="1" bgcolor="#97a3ca"></td>
<td width="1" height="1" bgcolor="#98a4cb"></td>
<td width="1" height="1" bgcolor="#99a5cc"></td>
<td width="1" height="1" bgcolor="#9aa6cc"></td>
<td width="1" height="1" bgcolor="#9ba7cd"></td>
<td width="1" height="1" bgcolor="#9ca8cd"></td>
<td width="1" height="1" bgcolor="#9da9ce"></td>
<td width="1" height="1" bgcolor="#9ea9ce"></td>
<td width="1" height="1" bgcolor="#9eaace"></td>
<td width="1" height="1" bgcolor="#9eaacf"></td>
<td width="1" height="1" bgcolor="#9fabcf"></td>
<td width="1" height="1" bgcolor="#a0abd0"></td>
<td width="1" height="1" bgcolor="#a0acd0"></td>
<td width="1" height="1" bgcolor="#a1acd0"></td>
<td width="1" height="1" bgcolor="#a1add0"></td>
<td width="1" height="1" bgcolor="#a2add0"></td>
<td width="1" height="1" bgcolor="#a2add1"></td>
<td width="1" height="1" bgcolor="#a3aed1"></td>
<td width="1" height="1" bgcolor="#a4aed1"></td>
<td width="1" height="1" bgcolor="#a5afd2"></td>
<td width="1" height="1" bgcolor="#a5afd1"></td>
<td width="1" height="1" bgcolor="#a6b1d2"></td>
<td width="1" height="1" bgcolor="#a7b0d2"></td>
<td width="1" height="1" bgcolor="#a7b2d2"></td>
<td width="1" height="1" bgcolor="#a8b1d3"></td>
<td width="1" height="1" bgcolor="#a8b3d3"></td>
<td width="1" height="1" bgcolor="#a9b3d3"></td>
<td width="1" height="1" bgcolor="#aab4d3"></td>
<td width="1" height="1" bgcolor="#abb4d3"></td>
<td width="1" height="1" bgcolor="#abb5d4"></td>
<td width="1" height="1" bgcolor="#acb5d4"></td>
<td width="1" height="1" bgcolor="#adb6d4"></td>
<td width="1" height="1" bgcolor="#adb6d5"></td>
<td width="1" height="1" bgcolor="#aeb6d4"></td>
<td width="1" height="1" bgcolor="#aeb7d5"></td>
<td width="1" height="1" bgcolor="#afb7d5"></td>
<td width="1" height="1" bgcolor="#b0b8d5"></td>
<td width="1" height="1" bgcolor="#b1b9d5"></td>
<td width="1" height="1" bgcolor="#b2b9d6"></td>
<td width="1" height="1" bgcolor="#b2b9d5"></td>
<td width="1" height="1" bgcolor="#b3bad6"></td>
<td width="1" height="1" bgcolor="#b4bbd6"></td>
<td width="1" height="1" bgcolor="#b5bbd7"></td>
<td width="1" height="1" bgcolor="#b5bcd7"></td>
<td width="1" height="1" bgcolor="#b6bcd7"></td>
<td width="1" height="1" bgcolor="#b7bdd7"></td>
<td width="1" height="1" bgcolor="#b8bdd7"></td>
<td width="1" height="1" bgcolor="#b8bed7"></td>
<td width="1" height="1" bgcolor="#b9bed8"></td>
<td width="1" height="1" bgcolor="#b9bfd8"></td>
<td width="1" height="1" bgcolor="#babfd8"></td>
<td width="1" height="1" bgcolor="#bcc0d9"></td>
<td width="1" height="1" bgcolor="#bcc0d8"></td>
<td width="1" height="1" bgcolor="#bdc1d9"></td>
<td width="1" height="1" bgcolor="#bec1d9"></td>
<td width="1" height="1" bgcolor="#bec2da"></td>
<td width="1" height="1" bgcolor="#bfc2da"></td>
<td width="1" height="1" bgcolor="#bfc3da"></td>
<td width="1" height="1" bgcolor="#c0c3da"></td>
<td width="1" height="1" bgcolor="#c1c3db"></td>
<td width="1" height="1" bgcolor="#c1c4db"></td>
<td width="1" height="1" bgcolor="#c2c4db"></td>
<td width="1" height="1" bgcolor="#c3c4db"></td>
<td width="1" height="1" bgcolor="#c3c5db"></td>
<td width="1" height="1" bgcolor="#c4c5dc"></td>
<td width="1" height="1" bgcolor="#c4c5db"></td>
<td width="1" height="1" bgcolor="#c5c6dc"></td>
<td width="1" height="1" bgcolor="#c6c7dc"></td>
<td width="1" height="1" bgcolor="#c6c6dc"></td>
<td width="1" height="1" bgcolor="#c7c7dc"></td>
<td width="1" height="1" bgcolor="#c8c8dc"></td>
<td width="1" height="1" bgcolor="#c9c9dd"></td>
<td width="1" height="1" bgcolor="#cac9dd"></td>
<td width="1" height="1" bgcolor="#cac9dc"></td>
<td width="1" height="1" bgcolor="#cbcadd"></td>
<td width="1" height="1" bgcolor="#cccbdd"></td>
<td width="1" height="1" bgcolor="#cccbdc"></td>
<td width="1" height="1" bgcolor="#cdccdd"></td>
<td width="1" height="1" bgcolor="#cdccdc"></td>
<td width="1" height="1" bgcolor="#ceccdd"></td>
<td width="1" height="1" bgcolor="#cfcddd"></td>
<td width="1" height="1" bgcolor="#d0cedd"></td>
<td width="1" height="1" bgcolor="#d1cfdd"></td>
<td width="1" height="1" bgcolor="#d1cfde"></td>
<td width="1" height="1" bgcolor="#d2d0de"></td>
<td width="1" height="1" bgcolor="#d3d1df"></td>
<td width="1" height="1" bgcolor="#d4d1df"></td>
<td width="1" height="1" bgcolor="#d4d2e0"></td>
<td width="1" height="1" bgcolor="#d5d2e0"></td>
<td width="1" height="1" bgcolor="#d5d3e0"></td>
<td width="1" height="1" bgcolor="#d6d4e0"></td>
<td width="1" height="1" bgcolor="#d7d4e0"></td>
<td width="1" height="1" bgcolor="#d8d4e0"></td>
<td width="1" height="1" bgcolor="#d7d4df"></td>
<td width="1" height="1" bgcolor="#d8d4df"></td>
<td width="1" height="1" bgcolor="#d8d3de"></td>
<td width="1" height="1" bgcolor="#d8d3dd"></td>
<td width="1" height="1" bgcolor="#d9d3dd"></td>
<td width="1" height="1" bgcolor="#d8d2dc"></td>
<td width="1" height="1" bgcolor="#d9d3dc"></td>
<td width="1" height="1" bgcolor="#d9d2dc"></td>
<td width="1" height="1" bgcolor="#d8d1da"></td>
<td width="1" height="1" bgcolor="#d9d1d9"></td>
<td width="1" height="1" bgcolor="#c3c5dc"></td>
<td width="1" height="1" bgcolor="#c8c8dd"></td>
<td width="1" height="1" bgcolor="#c9c9dc"></td>
<td width="1" height="1" bgcolor="#cbcadc"></td>
<td width="1" height="1" bgcolor="#cdcbdd"></td>
<td width="1" height="1" bgcolor="#cecddd"></td>
<td width="1" height="1" bgcolor="#d1cedd"></td>
<td width="1" height="1" bgcolor="#d2cfdd"></td>
<td width="1" height="1" bgcolor="#d3d1de"></td>
<td width="1" height="1" bgcolor="#d4d2df"></td>
<td width="1" height="1" bgcolor="#d6d3e0"></td>
<td width="1" height="1" bgcolor="#d6d3df"></td>
<td width="1" height="1" bgcolor="#d7d3de"></td>
<td width="1" height="1" bgcolor="#d8d5de"></td>
<td width="1" height="1" bgcolor="#d9d2db"></td>
<td width="1" height="1" bgcolor="#d9d2da"></td>
<td width="1" height="1" bgcolor="#d9d1d8"></td>
<td width="1" height="1" bgcolor="#dad1d8"></td>
<td width="1" height="1" bgcolor="#dad2d7"></td>
<td width="1" height="1" bgcolor="#dbd1d7"></td>
<td width="1" height="1" bgcolor="#dcd1d7"></td>
<td width="1" height="1" bgcolor="#ddd3d7"></td>
<td width="1" height="1" bgcolor="#ded2d7"></td>
<td width="1" height="1" bgcolor="#ded4d7"></td>
<td width="1" height="1" bgcolor="#dfd4d7"></td>
<td width="1" height="1" bgcolor="#e0d5d7"></td>
<td width="1" height="1" bgcolor="#e1d5d7"></td>
<td width="1" height="1" bgcolor="#e1d6d7"></td>
<td width="1" height="1" bgcolor="#e2d6d7"></td>
<td width="1" height="1" bgcolor="#e3d7d8"></td>
<td width="1" height="1" bgcolor="#e4d8d8"></td>
<td width="1" height="1" bgcolor="#e4d8d7"></td>
<td width="1" height="1" bgcolor="#e5d9d8"></td>
<td width="1" height="1" bgcolor="#e6dad8"></td>
<td width="1" height="1" bgcolor="#e7dad8"></td>
<td width="1" height="1" bgcolor="#e8dbd8"></td>
<td width="1" height="1" bgcolor="#eadcd8"></td>
<td width="1" height="1" bgcolor="#ebdcd8"></td>
<td width="1" height="1" bgcolor="#ebddd8"></td>
<td width="1" height="1" bgcolor="#ecddd8"></td>
<td width="1" height="1" bgcolor="#edded8"></td>
<td width="1" height="1" bgcolor="#edddd7"></td>
<td width="1" height="1" bgcolor="#eeded7"></td>
<td width="1" height="1" bgcolor="#eeded6"></td>
<td width="1" height="1" bgcolor="#efded6"></td>
<td width="1" height="1" bgcolor="#f0ded6"></td>
<td width="1" height="1" bgcolor="#f0ded5"></td>
<td width="1" height="1" bgcolor="#f0ded4"></td>
<td width="1" height="1" bgcolor="#f1ded4"></td>
<td width="1" height="1" bgcolor="#f1ded3"></td>
<td width="1" height="1" bgcolor="#f2ded3"></td>
<td width="1" height="1" bgcolor="#f1ded1"></td>
<td width="1" height="1" bgcolor="#f2ded1"></td>
<td width="1" height="1" bgcolor="#f3ded1"></td>
<td width="1" height="1" bgcolor="#f3ded0"></td>
<td width="1" height="1" bgcolor="#f3decf"></td>
<td width="1" height="1" bgcolor="#f3dece"></td>
<td width="1" height="1" bgcolor="#f4dece"></td>
<td width="1" height="1" bgcolor="#f4decd"></td>
<td width="1" height="1" bgcolor="#f5decc"></td>
<td width="1" height="1" bgcolor="#f5ddcb"></td>
<td width="1" height="1" bgcolor="#f6decc"></td>
<td width="1" height="1" bgcolor="#f6deca"></td>
<td width="1" height="1" bgcolor="#f7deca"></td>
<td width="1" height="1" bgcolor="#f7dec9"></td>
<td width="1" height="1" bgcolor="#f8dec9"></td>
<td width="1" height="1" bgcolor="#f8dec7"></td>
<td width="1" height="1" bgcolor="#f9dec7"></td>
<td width="1" height="1" bgcolor="#f9dec6"></td>
<td width="1" height="1" bgcolor="#f9ddc4"></td>
<td width="1" height="1" bgcolor="#fadec4"></td>
<td width="1" height="1" bgcolor="#fadec3"></td>
<td width="1" height="1" bgcolor="#fbdec2"></td>
<td width="1" height="1" bgcolor="#fbddc0"></td>
<td width="1" height="1" bgcolor="#fcddbf"></td>
<td width="1" height="1" bgcolor="#fddebf"></td>
<td width="1" height="1" bgcolor="#fddebe"></td>
<td width="1" height="1" bgcolor="#fdddbc"></td>
<td width="1" height="1" bgcolor="#fdddbb"></td>
<td width="1" height="1" bgcolor="#feddbb"></td>
<td width="1" height="1" bgcolor="#fdddba"></td>
<td width="1" height="1" bgcolor="#fedcb9"></td>
<td width="1" height="1" bgcolor="#fedcb8"></td>
<td width="1" height="1" bgcolor="#feddb8"></td>
<td width="1" height="1" bgcolor="#fedeb7"></td>
<td width="1" height="1" bgcolor="#fedcb6"></td>
<td width="1" height="1" bgcolor="#fedcb5"></td>
<td width="1" height="1" bgcolor="#fedbb4"></td>
<td width="1" height="1" bgcolor="#fedbb3"></td>
<td width="1" height="1" bgcolor="#fedab2"></td>
<td width="1" height="1" bgcolor="#fddab1"></td>
<td width="1" height="1" bgcolor="#fedab1"></td>
<td width="1" height="1" bgcolor="#fdd9b0"></td>
<td width="1" height="1" bgcolor="#fedab0"></td>
<td width="1" height="1" bgcolor="#fdd9ae"></td>
<td width="1" height="1" bgcolor="#fdd9ad"></td>
<td width="1" height="1" bgcolor="#fdd8ac"></td>
<td width="1" height="1" bgcolor="#fdd8ab"></td>
<td width="1" height="1" bgcolor="#fdd9aa"></td>
<td width="1" height="1" bgcolor="#fdd7a9"></td>
<td width="1" height="1" bgcolor="#fdd7a8"></td>
<td width="1" height="1" bgcolor="#fdd8a7"></td>
<td width="1" height="1" bgcolor="#fdd8a6"></td>
<td width="1" height="1" bgcolor="#fdd6a5"></td>
<td width="1" height="1" bgcolor="#fdd7a4"></td>
<td width="1" height="1" bgcolor="#fdd7a3"></td>
<td width="1" height="1" bgcolor="#fdd6a1"></td>
<td width="1" height="1" bgcolor="#fdd6a0"></td>
<td width="1" height="1" bgcolor="#fdd69f"></td>
<td width="1" height="1" bgcolor="#fed69f"></td>
<td width="1" height="1" bgcolor="#fed69e"></td>
<td width="1" height="1" bgcolor="#fed59c"></td>
<td width="1" height="1" bgcolor="#fed39b"></td>
<td width="1" height="1" bgcolor="#fed49a"></td>
<td width="1" height="1" bgcolor="#fed498"></td>
<td width="1" height="1" bgcolor="#fed397"></td>
<td width="1" height="1" bgcolor="#fed396"></td>
<td width="1" height="1" bgcolor="#fed294"></td>
<td width="1" height="1" bgcolor="#fed092"></td>
<td width="1" height="1" bgcolor="#fed191"></td>
<td width="1" height="1" bgcolor="#fece8f"></td>
<td width="1" height="1" bgcolor="#fece8e"></td>
<td width="1" height="1" bgcolor="#fecd8d"></td>
<td width="1" height="1" bgcolor="#fecc8a"></td>
<td width="1" height="1" bgcolor="#fecb89"></td>
<td width="1" height="1" bgcolor="#feca87"></td>
<td width="1" height="1" bgcolor="#fec986"></td>
<td width="1" height="1" bgcolor="#fec884"></td>
<td width="1" height="1" bgcolor="#fec782"></td>
<td width="1" height="1" bgcolor="#fec681"></td>
<td width="1" height="1" bgcolor="#fec57f"></td>
<td width="1" height="1" bgcolor="#fec37d"></td>
<td width="1" height="1" bgcolor="#fec27b"></td>
<td width="1" height="1" bgcolor="#fec17a"></td>
<td width="1" height="1" bgcolor="#febf78"></td>
<td width="1" height="1" bgcolor="#febf76"></td>
<td width="1" height="1" bgcolor="#feba6f"></td>
<td width="1" height="1" bgcolor="#feb76a"></td>
<td width="1" height="1" bgcolor="#feb668"></td>
<td width="1" height="1" bgcolor="#feb565"></td>
<td width="1" height="1" bgcolor="#feb563"></td>
<td width="1" height="1" bgcolor="#feb561"></td>
<td width="1" height="1" bgcolor="#feb460"></td>
<td width="1" height="1" bgcolor="#fdb35e"></td>
<td width="1" height="1" bgcolor="#fcb15a"></td>
<td width="1" height="1" bgcolor="#fcb159"></td>
<td width="1" height="1" bgcolor="#fcb057"></td>
<td width="1" height="1" bgcolor="#fcae55"></td>
<td width="1" height="1" bgcolor="#fcaa52"></td>
<td width="1" height="1" bgcolor="#fca851"></td>
<td width="1" height="1" bgcolor="#fca850"></td>
<td width="1" height="1" bgcolor="#fca64f"></td>
<td width="1" height="1" bgcolor="#fca44e"></td>
<td width="1" height="1" bgcolor="#fca34d"></td>
<td width="1" height="1" bgcolor="#fc9d4a"></td>
<td width="1" height="1" bgcolor="#fc9349"></td>
<td width="1" height="1" bgcolor="#fc8f48"></td>
<td width="1" height="1" bgcolor="#fc8c48"></td>
<td width="1" height="1" bgcolor="#fc8047"></td>
</tr>
</table>
That's not even a tenth of the code size though.Without tweaking the code to grab only particular gradient stops, it's faster to do it in Gimp.
Maybe one of our fine coders here could write something in Python or SCM to grab the colors of an image and create a gradient (GRD) file with it.It seems like i saw one before but i do not remember where.
PostPosted: Sat May 21, 2011 10:30 pm  (#9)
Rod: I like your tutorial better. It's much faster. If someone could work that into a script where you pick your colors in place of opening an editor, etc. awesome! :)
PostPosted: Fri Jul 01, 2011 1:18 pm  (#10)
That would be RobA's sample gradient along path
PostPosted: Fri Jul 01, 2011 2:33 pm  (#11)
I use RobA's script a lot for Photoshop gradients, etc. I'd love to see GIMP improve the gradient editor to make it easier to use for selecting colors and blending.
PostPosted: Fri Jul 01, 2011 3:04 pm  (#12)
I never even thought of Robs script.
Great idea! :)
PostPosted: Sat Jul 02, 2011 10:52 am  (#13)
I think the maximum amount of samples is limited with the current script but if you change line 117 to
SF-ADJUSTMENT "Number of Samples" (list 25 2 1024 1 10 0 SF-SLIDER)
you can have up to 1024 samples which works wonders when you sampling colors from photographs of real images that have complex colors it does wonders.
PostPosted: Sun Jul 03, 2011 6:20 pm  (#14)
Good idea! :bigthup
