It is currently Tue Nov 17, 2026 2:56 am
 Post subject: How do I select a pasted selection?
PostPosted: Mon Sep 14, 2020 5:55 pm  (#1)
Hi, super new to Gimp, only been using it a couple of days. Sorry if this question is repetitive but I searched the topics and didn't find anything similar that already answered it...
I made a selection on a layer using the smart scissors tool, then copied and pasted it onto the main layer that im working with. After resizing it, i clicked out and the selection was no longer "floating" or selected with the area of the dotted lines around it moving. Is there a way I can re-select the pasted image so that I can still edit and move it? Been Googling and Youtubing for awhile and still cant seem to figure it out. There's another pasted section I wasn't finished working with as well, but I can't seem to select it.
Help, please!
Thanks
 Post subject: Re: How do I select a pasted selection?
PostPosted: Mon Sep 14, 2020 8:17 pm  (#2)
Help, please!
Thanks
When you say you can't select it again.
How is it that you are trying to select this and failing?
If it was pasted into a layer,
which was already occupied by something.
It is now part of this layer and would need to be selected again using the :freesel Free Select Tool,
or some other selection method.
This is determined by what you see within this layer and how it's composed.
PostPosted: Mon Sep 14, 2020 8:24 pm  (#3)
Hi there!
Thanks, that's very helpful. I read/researched a lot and have a better grasp now of what layers actually are (I didn't quite understand before so I think that was my mistake) and how to manage different selections. Just takes awhile to get familiarized.
Thanks so much
PostPosted: Mon Sep 14, 2020 8:30 pm  (#4)
arieldelrey wrote:
Hi there!
Thanks so much
Ok!
Perhaps adding a new layer with transparency.
To paste the copied selection into,
would have worked better in your case.
