It is currently Sun Nov 22, 2026 1:11 am
 Post subject: Pixel Art Help
PostPosted: Thu Sep 17, 2020 10:52 am  (#1)
Hello I need help with some pixel art that i do, its for a game. The file is .gif, and i have to change the hair color.Image
 Post subject: Re: Pixel Art Help
PostPosted: Thu Sep 17, 2020 11:56 am  (#2)
I did it like this.
Menu: Tools: Selection Tools, By Color Select.
In the left side Tool Options box.
Mode: add to the selection.
Threshold: Around 75
Clicked over the darker blue.
Click again over the lighter blue part that wasn't selected.
Menu: Colors, Hue Saturation.
I've seen only one color altered easier but can not remember how it was done.
You better wait for the gurus to reply.
PostPosted: Fri Sep 18, 2020 3:01 am  (#3)
I used the select by colour tool and selected all of the hair then colorized it. You could do the same thing with the fuzzy select tool.
