It is currently Tue Nov 17, 2026 2:08 am
 Post subject: A huge dump of GEGL Graphs from my computer - study them
PostPosted: Sun Feb 26, 2023 9:19 pm  (#1)
Here is a dump of GEGL Graphs from my computer - it includes the graphs of popular filters of mine such as Glossy Balloon
median-blur  percentile=90 alpha-percentile=290
gaussian-blur std-dev-x=4 std-dev-y=4
id=3
screen aux=[ ref=3  emboss  type=bumpmap azimuth=90  elevation=15 ]
id=3
This is the raw GEGL Graph to Glossy Balloon - many more graphs like this are found in the collection.
There are more graphs in other threads like
viewtopic.php?f=10&t=19463&start=40
viewtopic.php?f=4&t=19979
viewtopic.php?f=8&t=19469&hilit=graph+do#p273287
gegl_graph_collection.zip [153.39 KiB]
Downloaded 363 times
 Post subject: Re: A huge dump of GEGL Graphs from my computer - study them
PostPosted: Sun Feb 26, 2023 9:28 pm  (#2)
Every GEGL Filter I make is first conceived inside Gimp's GEGL Graph filter by chaining GEGL Operations together. These Graph's show the development process I went through when making these filters - and even graphs that I never got a chance to turn into filters. If someone takes the time to study my GEGL Graphs they will go to new heights with Gimp
PostPosted: Tue Feb 28, 2023 7:44 pm  (#3)
These files are .txt files. If they are usable, where do they go?
PostPosted: Tue Feb 28, 2023 7:56 pm  (#4)
Paste the text file info inside GEGL Graph. Do NOT import it.
#rock text custom bevel
median-blur radius=-1 alpha-percentile=70
noise-spread amount-x=3 amount-y=3
gimp:threshold-alpha
custom-bevel blendmode=Plus
bloom strength=6
id=ls
gimp:layer-mode layer-mode=behind aux=[ ref=ls long-shadow-pd angle=70 length=9 lightness=99 bloom strength=13 ]
crop
denoise-dct patch-size=size8x8 sigma=7
id=slemboss
gimp:layer-mode opacity=0.50 layer-mode=softlight aux=[ ref=slemboss emboss depth=10 elevation=60 azimuth=50 ]
levels in-low=0.130
dropshadow x=2.38 y=2.38 radius=3 opacity=0.65
brightness-contrast brightness=0.04
noise-reduction iterations=3
id=color
multiply aux=[ ref=color color-overlay value=#ffd700 ]
You will need my custom filters for these Graphs to work.
