It is currently Tue Nov 17, 2026 4:32 am
Post new topic Reply to topic  [ 196 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
 Post subject: Custom Fonts from GimpLearn 2019
PostPosted: Tue Jun 06, 2023 1:10 pm  (#1)
Yes it may be 2023 but I am adding the custom fonts that I created in 2019 and uploaded to GimpLearn because they exceeded the 6Mb limit here.
I would add other contributors' work but sadly I only have my own copies.
If you download the ones that have been zipped and split into smaller chunks you can extract them and re-asemble them using File>>Open as Layers... or you can download and use my Stitcher plug-in to do the job for you...
Custom_Font_File_Stitcher_v_02.zip [3.95 KiB]
Downloaded 18289 times
More information and a pdf helper to download here
Here is another plug-in that will re-assemble custom fonts split apart in a different way - aimed mainly at those custom fonts which contain accented characters. It cannot be used with files intended to be used with Stitcher. Individual postings will make it clear which of the two plug-ins is required.
Custom_Font_File_Re-assembler_v_02.zip [4.72 KiB]
Downloaded 15190 times
 Post subject: Re: Custom Fonts from GimpLearn 2019
PostPosted: Tue Jun 06, 2023 1:15 pm  (#2)
Starting with a brushed font called Autumn. This custom font has rather large flourishes on some of the numbers.
Use Stitcher from post#1 to re-assemble the three custom font files.
Autumn.xcf [5.36 MiB]
Downloaded 15372 times
Autumn_1.xcf [4.11 MiB]
Downloaded 15136 times
Autumn_2.xcf [4.79 MiB]
Downloaded 15266 times
PostPosted: Tue Jun 06, 2023 1:52 pm  (#3)
Use Stitcher from post#1 to re-assmble the custom font files (first two will need extracting).
Aclonica_Blue_Lattice.7z [3.64 MiB]
Downloaded 15352 times
Aclonica_Blue_Lattice_1.7z [3.17 MiB]
Downloaded 15389 times
Aclonica_Blue_Lattice_2.xcf [3.39 MiB]
Downloaded 15245 times
PostPosted: Tue Jun 06, 2023 3:20 pm  (#4)
Use Stitcher from post#1 to re-assemble the four custom font files (two in this post and two in the next).
Decrepit_Yellow_Lattice.7z [5.45 MiB]
Downloaded 14876 times
Decrepit_Yellow_Lattice_1.7z [4.04 MiB]
Downloaded 15346 times
PostPosted: Tue Jun 06, 2023 3:22 pm  (#5)
Decrepit_Yellow_Lattice_2.xcf [5.91 MiB]
Downloaded 16137 times
Decrepit_Yellow_Lattice_3.xcf [4.4 MiB]
Downloaded 15371 times
PostPosted: Tue Jun 06, 2023 3:44 pm  (#6)
Use Stitcher from post#1 to re-assemble the three custom font files after extracting.
Pinocchio_LineFest.7z [3.56 MiB]
Downloaded 15673 times
Pinocchio_LineFest_1.7z [3.11 MiB]
Downloaded 15396 times
Pinocchio_LineFest_2.7z [1.89 MiB]
Downloaded 15082 times
PostPosted: Wed Jun 07, 2023 2:16 am  (#7)
Use Stitcher from post#1 to re-assemble the two custom font files.
ZeitGeisterbahn_Colourful.7z [4.87 MiB]
Downloaded 15533 times
ZeitGeisterbahn_Colourful_1.xcf [5.32 MiB]
Downloaded 15209 times
PostPosted: Wed Jun 07, 2023 3:51 am  (#8)
Cloud_Control_PastelBlue2.xcf [5.54 MiB]
Downloaded 31788 times
Cloud_Control_PastelBlue2_1.xcf [3.71 MiB]
Downloaded 15437 times
PostPosted: Wed Jun 07, 2023 4:44 am  (#9)
Emerald.7z [5.28 MiB]
Downloaded 15551 times
PostPosted: Wed Jun 07, 2023 6:38 am  (#10)
Image from Wikipedia Commons.
Chunky_Soft_VGogh_Blossom.7z [4.35 MiB]
Downloaded 15490 times
Chunky_Soft_VGogh_Blossom_1.7z [3.33 MiB]
Downloaded 14886 times
PostPosted: Wed Jun 07, 2023 7:18 am  (#11)
New_Serif_Purple_Faze.7z [5.56 MiB]
Downloaded 14767 times
New_Serif_Purple_Faze_1.7z [3.46 MiB]
Downloaded 14488 times
PostPosted: Wed Jun 07, 2023 8:05 am  (#12)
Extract and use Stitcher from post#1 to re-assemble the two custom font files.
Chunky_Sunset.7z [5.57 MiB]
Downloaded 14326 times
Chunky_Sunset_1.7z [3.97 MiB]
Downloaded 14699 times
PostPosted: Wed Jun 07, 2023 8:23 am  (#13)
Grand_Abstract.7z [5.08 MiB]
Downloaded 14728 times
Grand_Abstract_1.7z [2.8 MiB]
Downloaded 15045 times
PostPosted: Wed Jun 07, 2023 12:52 pm  (#14)
Metamorphous_Caps_Regal.7z [4.65 MiB]
Downloaded 15247 times
Metamorphous_Caps_Regal_1.7z [3.84 MiB]
Downloaded 14883 times
PostPosted: Wed Jun 07, 2023 1:13 pm  (#15)
Extract the first file and use Stitcher from post#1 to re-assemble the two custom font files.
Berkshire_Feathery.7z [4.51 MiB]
Downloaded 14644 times
Berkshire_Feathery_1.xcf [3.71 MiB]
Downloaded 14752 times
PostPosted: Wed Jun 07, 2023 1:47 pm  (#16)
Extract the files and use Stitcher from post#1 to re-assemble the two custom font files.
Qumkellka_Colourful.7z [5.35 MiB]
Downloaded 42850 times
Qumkellka_Colourful_1.7z [3.54 MiB]
Downloaded 14543 times
PostPosted: Wed Jun 07, 2023 3:36 pm  (#17)
Alice_Caps_Bottled.7z [4.85 MiB]
Downloaded 14978 times
Alice_Caps_Bottled_1.7z [3.68 MiB]
Downloaded 16971 times
PostPosted: Thu Jun 08, 2023 1:40 am  (#18)
Extract the files and use Stitcher from post#1 to re-assemble the three custom font files.
Ribeye_Red_Pearl.7z [4.26 MiB]
Downloaded 14530 times
Ribeye_Red_Pearl_1.7z [3.64 MiB]
Downloaded 14975 times
Ribeye_Red_Pearl_2.7z [3.12 MiB]
Downloaded 14826 times
PostPosted: Thu Jun 08, 2023 2:16 am  (#19)
BigMummy_Radiance.7z [4.98 MiB]
Downloaded 14568 times
BigMummy_Radiance_1.7z [3.59 MiB]
Downloaded 14553 times
BigMummy_Radiance_2.7z [3.22 MiB]
Downloaded 14660 times
PostPosted: Thu Jun 08, 2023 3:02 am  (#20)
Glametrix_BlueBoard.7z [3.43 MiB]
Downloaded 14049 times
Glametrix_BlueBoard_1.7z [3.36 MiB]
Downloaded 14837 times
