It is currently Tue Nov 17, 2026 4:22 am
Post new topic Reply to topic  [ 1172 posts ]  Go to page 1, 2, 3, 4, 5 ... 59  Next
 Post subject: Custom Fonts for 2024
PostPosted: Sun Jan 07, 2024 10:56 am  (#1)
A place to add custom fonts for 2024 – and Happy New Custom Fonting to everyone.
If you are new to the idea of custom fonts and have just found your way here I have provided a little information at the end of this post.
I have updated the Stitcher plug_in for re-assembling custom font files that have been split into smaller parts. It works with earlier versions of Splitter.
Custom_Font_File_Stitcher_v_03.zip [3.92 KiB]
Downloaded 11496 times
Information for new custom fonters
Custom fonts are a way of transforming plain or coloured text by adding effects, light and texture to the characters that you use in your Gimp creations.
Custom font files only work in Gimp: A file consists of a set of layers - one layer is used to display one character. The file may also contain a set of kerning paths that can be used to determine the spacing (kerning) between characters.
The image below shows unkerned and kerned text.
You will need a plug-in or filter to display the characters in Gimp. Search Gimp Scripts and Plugins
If you are interested in making your own custom fonts, there are plug-ins to make custom fonts from ordinary fonts or you can create your own custom fonts from scratch using Gimp. If you use an existing font make sure that the font is free to use both for personal and commercial use. Some fonts download with a license in a compressed bundle but there are many others that come without any documentation. Do your best to find out if the author of the original font has imposed any restrictions on the use of his/her fonts. I am extremely grateful to those who make their fonts freely available.
Some custom fonts need to be unzipped after download, because of the filesize limit of 6MB here on GimpChat. Some custom fonts are available with more than one file of characters and need to be re-assembled after downloading and unzipping. This can be done by using the ‘Open as Layers...’ dialog from the ‘File’ menu option in Gimp or you can use the Stitcher plug-in (now at version 0.3) to do this for you.
 Post subject: Re: Custom Fonts for 2024
PostPosted: Sun Jan 07, 2024 11:02 am  (#2)
A new font to start off the New Year...
Download, unzip and re-assemble with Stitcher v0.3 from post#1.
Steady_Serif_Pelaw3d.7z [4.7 MiB]
Downloaded 11655 times
Steady_Serif_Pelaw3d_1.7z [3.24 MiB]
Downloaded 11073 times
PostPosted: Mon Jan 08, 2024 5:34 am  (#3)
Here is custom font 3207 for the new year. :paint
Download, unzip and reassemble the files with Stitcher v0.3 from post #1.
Gimp_3210_2.rar [2.7 MiB]
Downloaded 10677 times
Gimp_3210_1.rar [3.4 MiB]
Downloaded 11338 times
Gimp_3210.rar [2.86 MiB]
Downloaded 11240 times
PostPosted: Tue Jan 09, 2024 2:50 am  (#4)
Steady_GAC3d.7z [5.76 MiB]
Downloaded 9220 times
Steady_GAC3d_2.7z [4.27 MiB]
Downloaded 10982 times
PostPosted: Wed Jan 10, 2024 5:29 am  (#5)
I decided to add a heavier weighting to this custom font style.
Steady_Serif_Broad_Penshaw3d.7z [4.28 MiB]
Downloaded 42360 times
Steady_Serif_Broad_Penshaw3d_1.7z [3.53 MiB]
Downloaded 9928 times
Steady_Serif_Broad_Penshaw3d_2.7z [2.76 MiB]
Downloaded 9533 times
PostPosted: Wed Jan 10, 2024 12:02 pm  (#6)
DJ; Ok for sharing custom fonts. :paint
PostPosted: Thu Jan 11, 2024 3:13 am  (#7)
DJ: :bigthup
Download, unzip the first two files and re-assemble with Stitcher v0.3 from post#1.
Using a sans serif version of the heavier weighting of this custom font style.
Steady_Broad_Zing3d.7z [4.17 MiB]
Downloaded 10175 times
Steady_Broad_Zing3d_1.7z [3.34 MiB]
Downloaded 9600 times
Steady_Broad_Zing3d_2.xcf [5.87 MiB]
Downloaded 10026 times
PostPosted: Thu Jan 11, 2024 4:18 am  (#8)
Here is custom font 3205.
Gimp_3205.xcf [4.1 MiB]
Downloaded 9898 times
Gimp_3205_1.xcf [4.85 MiB]
Downloaded 9367 times
PostPosted: Fri Jan 12, 2024 3:28 am  (#9)
And an italicised version of Steady using part of an image from Unsplash...
Steady_Italic_Fringed.7z [5.87 MiB]
Downloaded 10064 times
Example of 3D use...
PostPosted: Sat Jan 13, 2024 3:59 am  (#10)
Steady_Serif_Chequer3d.7z [5.72 MiB]
Downloaded 10112 times
Steady_Serif_Chequer3d_1.7z [4.41 MiB]
Downloaded 9873 times
PostPosted: Sat Jan 13, 2024 4:13 am  (#11)
Here is custom font 3208.
Download, unzip and reassemble the files with Stitcher v0.3.
Gimp_3208.rar [2.31 MiB]
Downloaded 9198 times
Gimp_3208_1.rar [1.9 MiB]
Downloaded 30090 times
PostPosted: Sun Jan 14, 2024 4:26 am  (#12)
Download the files, unzip the first and re-assemble with Stitcher v0.3 from post#1.
PityMe_Bloop.7z [4.69 MiB]
Downloaded 9876 times
PityMe_Bloop_1.xcf [4.65 MiB]
Downloaded 14983 times
Example of 3d play...
PostPosted: Sun Jan 14, 2024 9:24 am  (#13)
Here is custom font 3212.
Gimp_3212.rar [2.82 MiB]
Downloaded 9975 times
Gimp_3212_1.rar [3.3 MiB]
Downloaded 9767 times
Gimp_3212_2.rar [2.57 MiB]
Downloaded 9753 times
PostPosted: Mon Jan 15, 2024 2:40 am  (#14)
Platelets.7z [4.72 MiB]
Downloaded 9648 times
PostPosted: Wed Jan 17, 2024 2:50 am  (#15)
PityMe_Infusion.7z [4.2 MiB]
Downloaded 14950 times
PityMe_Infusion_1.xcf [4.24 MiB]
Downloaded 2471 times
PostPosted: Wed Jan 17, 2024 4:00 am  (#16)
Here is custom font 3209.
Gimp_3209.rar [3.62 MiB]
Downloaded 2524 times
PostPosted: Wed Jan 17, 2024 4:02 am  (#17)
Here is custom font 3211.
Gimp_3211.rar [3.48 MiB]
Downloaded 2714 times
PostPosted: Fri Jan 19, 2024 3:33 am  (#18)
FlimFlam.7z [5.04 MiB]
Downloaded 2851 times
PostPosted: Fri Jan 19, 2024 6:39 pm  (#19)
Custom font plugins do not appear in Gimp 2.10.36.
:bawl :bawl :bawl :bawl :bawl :bawl :bawl :bawl :bawl :bawl :bawl :bawl :bawl :bawl
PostPosted: Sat Jan 20, 2024 4:42 am  (#20)
DJ: For information, the custom font plugins work for me under Win 10 with Gimp 2.10.36. :paint
