It is currently Tue Nov 17, 2026 12:42 am
 Post subject: A Simple Backup Option For Gimp
PostPosted: Sat Feb 21, 2026 6:34 pm  (#1)
Microsoft Windows XP – Windows 11 Version
Once you unzip the Zip file you should find only 2 files
BackupNow.bat and how to Setup.pdf
You want to copy the Backup.Bat file to your Gimp 3 folder under your folder name in
Roaming. Note this will work with any Gimp version you are currently using. See the
following image with the orange highlighted for the folder location.
Once you have the Backup file copied there, you want to right click it and
“Show More Options”, depending on your windows setup, select “Send To” and then
“Desktop” to create a short cut to your Desk Top for it.
How does this work.
This little Batch file will copy all files and folder and Sub Folder where you put it
to a D Drive, what ever that might be, whether a USB Flash Drive or a Backup Drive.
Note: it will not copy or setup files to be copied to DVD Burners. Sorry!
The way it works is that it checks to see what is already in the target Drive Letter D
by the time stamp of each File and Folder. If any of them have a different name or an
older time stamp or if its just a new file, it will copy them there. For example: If a file
has been updated but has the same file name, it will replace it with the new version
without asking you because the time stamp has changed. This is important to know,
because it will never delete any files from the D Drive (targeted location), because it
does not check to see if you have deleted any files from your Gimp sub folder and make
an exact copy by deleting them on D Drive as well. That something you’ll have to do
manually. The Backup is setup to look for a Drive that is Label D to work with. If it is
not present or can be found. It will give you an error message and stop and you can
return to the Backup Menu to exit.
 Post subject: Re: A Simple Backup Option For Gimp
PostPosted: Sat Feb 21, 2026 7:01 pm  (#2)
Option 1: Does what it says.
Option 2: Change Drive letter Information
Explanation of Option 2
For those who have a large Main Drive and have it partitioned to have more
than 1 drive letter they can manually change the default of where it copies
the files to. If you want to change the default to a higher Drive letter, for
whatever reason. I have given note of all the line of codes where to make the
changes, so you can fix it to backup in a different location. If you know the basic
of batch programming from the DOS. Select Option 2 of menu for more information.
Again, this is a very simple Backup Batch file and shouldn’t be to much of a problem
to adjust to your needs. If you decide to change the drive letter, just open the “bat”
file with a text editor and not a word processor and make the changes you want.
What to expect
Once you have close all your file Explorer(s) Windows. And return to your desktop,
you should now have an extra Icon on your desktop, something like this one.
Right click on the Icon and rename it to Gimp Backup for example. There is a way
to change the Icon to something else if don’t like how it looks by right clicking and go to properties
then click change Icon. Now your all setup and just need a USB Flash Drive to back up to. I
recommend an empty one to start with until you get the hang of thing. Once your D Drive is
ready to use, click on the icon to open the Backup Menu options and enter option 1 and press
enter to get thing going. Once it begins to copy files you should see something like this on your screen.
On the left side it of each line, you’ll see where the file is coming from, in this
case the C Drive and after that the folder called 3.0 with a file named pluginrc
being copied from where the batch file is located. Once it get all the files copied it
will display the number of files copied and how long it took to copied all the files
to the D Drive. You can do the same for your “GEGL-0.4” folder of Gimp and backup
you plug-ins from there as well, just repeat the same steps as for your Gimp files,
placing the BackNow.bat where your plug-ins are located..
I use it all the time, with a flash drive just for Gimp with all my graphics I might ever use.
And anything else I create and want saved right away. Just an Ideal I thought you might
be interested working with. I been doing this for years now. I even use it for My Document
folder under registered program 2026.
Please give some feedback if you use it.
BackupNow.zip [198.1 KiB]
Downloaded 204 times
Intel(R) Core(TM) Ultra 7
