It is currently Wed Nov 18, 2026 6:56 am
 Post subject: Matrix Theme for Gimp-2.10.38 RC1
PostPosted: Tue Nov 17, 2026 12:27 am  (#1)
After checking out the Gimp-3.0 theme "Matrix" quietreader posted i decided to try and make one for Gimp-2.10. :geek
As far as i now this theme will work in Windows but i am not sure of Linux or Mac. You will have to test it yourselves.
This theme does use the pixmap dll GTK-2.0 engine fiie so maybe you can find the correct executable for Linux i don't know.
Some image examples of the Gimp loader, and Gimp open in full single window mode.
I did keep the menu text lighter to keep other items more visible.
Hope you like the theme. :bigthup
I did get one error window loading the Gimp program and i just selected restart Gimp and had no further problems.
If you get any errors or Gimp crashes just restart. :bigthup
The theme also uses the font MS Comic Sans at size 11 (which can be changed in the gtkrc file.)
Installation Directions-
Just unzip to your user/themes folder and restart Gimp. Go to Edit>Preferences>Themes and select the Matrix theme.
Enjoy!
Matrix_Dynamic_RD.7z [978.71 KiB]
Downloaded 4 times
