It is currently Fri Aug 07, 2026 3:23 pm
 Post subject: The Under Font (and Over font)
PostPosted: Tue Sep 27, 2011 1:17 pm  (#1)
This is new in daFont. This font looks like it would make great animated brushes.
http://www.dafont.com/under.font
Font made to go over the Under font.
http://www.dafont.com/over.font
I made a brush just to see what happened and it's kind of nice. :mrgreen:
I used the lower case X and rotated it in 60 degree increments for a 6-layer, grayscale, animated brush. I've attached the brush if anyone would like to have it.
under-x.gih [788.51 KiB]
Downloaded 175 times
 Post subject: Re: The Under Font
PostPosted: Tue Sep 27, 2011 1:22 pm  (#2)
Thanks O! :)
PostPosted: Tue Sep 27, 2011 1:25 pm  (#3)
Any idea what the text font (the "over" font?) used in the example graphic was?
PostPosted: Tue Sep 27, 2011 3:06 pm  (#4)
They used the Over font. http://www.dafont.com/over.font
PostPosted: Tue Sep 27, 2011 3:41 pm  (#5)
thanks to who ever posted the link to dafont a while back, its come in real handy
i like the way you can input some text to see what it's going to look like
-is there a way to use/convert them for use in all windows apps..like word or thunderbird
PostPosted: Tue Sep 27, 2011 4:00 pm  (#6)
Thank you ever so much. I haven't been able to download it yet but that is seemingly only owing to the website being "under construction".
PostPosted: Tue Sep 27, 2011 4:44 pm  (#7)
I put all my fonts in my Windows system folder. Windows 7, click start, type in fonts, open the fonts folder and dump all your fonts in there. I don't have any in Gimp. I can use all those fonts no matter what I am working on. email, Word etc etc.
PostPosted: Tue Sep 27, 2011 4:57 pm  (#8)
This could be cool for creating a secret painted message but you send just a text file and the other person has to know what font was used. How cool that would be. lol
 Post subject: Re: The Under Font (and Over font)
PostPosted: Tue Sep 27, 2011 5:45 pm  (#9)
Thanks so much Molly..works great
PostPosted: Tue Sep 27, 2011 10:34 pm  (#10)
Another font that would work nicely with the Under font, the Two AM font.
PostPosted: Wed Sep 28, 2011 4:11 am  (#11)
If you click on any of the font graphics on his website, it will take you to the dafont.com section of his hosted fonts. All his completed fonts are listed there.
