It is currently Thu Oct 08, 2026 2:30 am
 Post subject: Some Halloween Treats for you all!
PostPosted: Wed Oct 19, 2011 12:02 pm  (#1)
*my best evil sounding, cackling laugh* :)
Every once in a while Dogwaffle's creator sends me some cool sketches by other artists to play with.Because i have a license for the Pro version they are free for me to use.
They're free for you to use as practicing material for coloring, tracing, enhancing. If you want to make commercial use of your artwork derived from these you will need to please contact Jon at the Dogwaffle website.
 Post subject: Re: Some Halloween Treats for you all!
PostPosted: Wed Oct 19, 2011 12:10 pm  (#2)
Some pretty good sketching there Rod.
PostPosted: Wed Oct 19, 2011 12:13 pm  (#3)
The bottom two has alot of detail in them
PostPosted: Wed Oct 19, 2011 12:25 pm  (#4)
They are not mine, as i said they are from Jon.
Feel free to color them and play with them.I thought it would be fun. :)
PostPosted: Wed Oct 19, 2011 3:19 pm  (#5)
Great sketches!!! Thanks Rod.
PostPosted: Wed Oct 19, 2011 3:22 pm  (#6)
That's a nice one Lorri! :)
You are very welcome O.If i get any more in the future i will be sure to share them.
PostPosted: Wed Oct 19, 2011 3:35 pm  (#7)
How about a little colored pencil effect? :)
Either take another image and place it on top in screen mode, or create a transparent layer on top and paint or sketch in screen, or another layer mode.This one has the Rodilius puppy image behind it.
PostPosted: Wed Oct 19, 2011 9:59 pm  (#8)
Last image is great for working with layers.
PostPosted: Thu Oct 20, 2011 4:26 pm  (#9)
Fun!
PostPosted: Thu Oct 20, 2011 5:38 pm  (#10)
Is that a checkered pattern behind the original O?
Pretty nifty looking! :)
PostPosted: Thu Oct 20, 2011 6:41 pm  (#11)
They are all great for using in Inkscape also.Just use the tools to create each different shape and color them in with fills, patterns, or gradients.Then you can scale them to whatever size you want.
You could make some pretty cool Halloween posters for parties! :)
PostPosted: Thu Oct 20, 2011 7:53 pm  (#12)
No, it's a stock image from Stock Xchng. I scaled it to the dimensions of the drawing.
Click to view it here.
PostPosted: Thu Oct 20, 2011 8:43 pm  (#13)
I would have never guessed that was the bg image. Great! :)
