It is currently Thu Oct 08, 2026 5:51 pm
 Post subject: 400x 400 steampunk sepia pattern
PostPosted: Sun Nov 27, 2011 7:04 am  (#1)
 Post subject: Re: 400x 400 steampunk sepia pattern
PostPosted: Sun Nov 27, 2011 7:11 am  (#2)
I love the sepia PC, think I will steal that one. :teeth thanks for sharing
PostPosted: Sun Nov 27, 2011 7:17 am  (#3)
Nice! :)
Thanks PC.
Is this a new GMIC filter setting in one of your filters?
If so where do i locate it?
Thanks again.
PostPosted: Sun Nov 27, 2011 9:56 am  (#4)
yes Rod i added 2 new options "Negative" and "3D sepia" to "Seamless Deco" and "Symmetry Masters"
here the effect of the new option
NORMAL
NEGATIVE
3D Sepia
NEGATIVE + 3D Sepia
That was Symmetry Master but is the same for Seamless Deco
BUT I DIDN?T UPLOAD YET i want check if all the presets works (in the option "PhotoComix preset" )
Humm.. that is a bit difficult to test because i already know they work on my PC the point is be sure they will work on the others,,,anyway if somebody want to try now i may paste the code
I changed function name so it would not conflict with the older version (i think it will replace the older version but i want leave a bit of time ,in case someone as presets to adapt to the new version.
(in case adapt preset it is very easy...but too lazy now to write a not requested how to )
PostPosted: Sun Nov 27, 2011 10:02 am  (#5)
For the impatient here the code
#@gimp  Seamless Deco 2 : gimp_mad_rorscharchp2,gimp_mad_rorscharchp2
#@gimp : Scale = float(3,0,15)
#@gimp : Mixer = choice ("Average","Grain Extract","Vivid Edges","Difference", "Exclusion"," Negation")
#@gimp : sep = separator()
#@gimp : Line = float(50,0,100)
#@gimp : Smoothness = float(1,0,5)
#@gimp : Sharpen = float(300,0,1000)
#@gimp : Remix = choice ( "Vivid Edges", "Average", "Difference","Negation","Dark Edges")
#@gimp : PhotoComix Preset = choice( "Neat Merge","Lighty Smooth","Dream","Moody" "Soft","Naif","Dark Boost","Whitening"," None- Skip" )
#@gimp : Negative = bool(0)
#@gimp : 3D Sepia = bool(0)
#@gimp : Activate Mirror = choice ("No-Skip","XY Mirror","2XY Mirror")
#@gimp : note = note("WARNING,"Expanding Mirrors" multiply image size of x4 or if "2XY Mirrors" x9")
#@gimp : Expanding Mirrors = bool(0)
#@gimp : sep = separator(), note = note("<small>Author : <i>PhotoComix</i>.      Latest update : <i>2011/11/13</i>.</small>")
gimp_mad_rorscharchp2 :
-gimp_rorschach $1,1,1
--mirror y
-if {$2==0} -gimp_compose_average 1,0
-elif {$2==1} -gimp_compose_grainextract 1,0
-elif {$2==1} -gimp_compose_vividedges 1,1,0.5,1 -endif
--gimp_plaid_texture $3,2,0,90,$4,$5
-if {$6==0} -gimp_compose_vividedges 1,1,0.5,1
-elif {$6==1} -gimp_compose_average 1,0
-elif {$6==2} -gimp_compose_difference 1,0
-elif {$6==3} -gimp_compose_negation 1,0
-elif {$6==4} -gimp_compose_negation 1,0
-elif {$6==5} -gimp_compose_darkedges 1,1,0.8,1 -endif
-if {$7==0} -gimp_graphic_novelfxl 0,2,6,5,20,0,0.62,14,0,1,0.5,0.78,1.92,0,0,12,1,1,1,0.5,0.8,1.28,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$7==1}-gimp_graphic_novelfxl 0,7.2,14.65,5,20,0,1.06,36.14,0,1,0.5,0.85,1.93,0,0,8,1,1,1,0.5,0.95,2.89,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$7==2} -gimp_graphic_novelfxl 0,7.22892,14.6506,5,20,0,1.6,36.1,0,1,0.5,0.6,3.6,0,0,11,1,1,1,0.5,0.8,2.16,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,7,1,1,1,0.5,0.45,1
-elif {$7==3}  -gimp_graphic_novelfxl 0,7.22892,14.6506,5,20,0,1.59036,36.1446,0,1,0.5,0.590361,3.61446,0,1,17,1,1,1,0.5,0.795181,2.16867,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,7,1,1,1,0.5,0.45,1
-elif {$7==4} -gimp_graphic_novelfxl 0,7.22892,14.6506,5,20,0,1.59036,36.1446,0,1,0.5,0.855422,1.92771,0,0,8,1,1,1,0.5,0.373494,2.89157,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$7==5} -gimp_graphic_novelfxl 1,7.22892,14.6506,5,20,0,1.06024,14,0,1,0.5,0.855422,1.3253,0,0,12,1,1,1,0.5,0.8,1.28,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$7==6} -gimp_graphic_novelfxl 1,7.22892,14.6506,5,20,0,1.06024,36.1446,0,1,0.5,0.855422,1.92771,0,0,7,1,1,1,0.5,0.951807,1.92771,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$7==7} -gimp_graphic_novelfxl 1,7.22892,14.6506,5,20,0,1.59036,36.1446,0,1,0.5,0.590361,3.61446,0,1,18,1,1,1,0.5,0.795181,2.16867,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1 -endif
-if {$8==1} -negative -endif
-if {$9==1} -gimp_cfx 10,0,0,0,0,0 -endif
-if {$10==1} -gimp_array_mirror 1,0,0,2,0,$11
-elif {$10==2} -gimp_array_mirror 1,0,0,3,0,$11 -endif
####################    SYMMETRY MASTER    ###############################
#@gimp  Symmetry Master 2: gimp_viralx,gimp_viralx
#@gimp : PhotoComix Preset = choice( "Neat Merge","Lighty Smooth","Dream","Moody","Soft","Naif","Dark Boost","Whitening"," None- Skip" )
#@gimp : Activate Mirror = choice ("No-Skip", XY Mirror"," 2XY Mirror")
gimp_viralx :
--mirror y
--gimp_array_mirror 1,0,0,2,0,0
-if {$3==0} -gimp_compose_vividedges 1,1,0.5,1
-elif {$3==1} -gimp_compose_average 1,0
-elif {$3==2} -gimp_compose_difference 1,0
-elif {$3==3} -gimp_compose_negation 1,0
-elif {$3==4} -gimp_compose_negation 1,0
-elif {$3==5} -gimp_compose_darkedges 1,1,0.8,1 -endif
-if {$4==0} -gimp_graphic_novelfxl 0,2,6,5,20,0,0.62,14,0,1,0.5,0.78,1.92,0,0,12,1,1,1,0.5,0.8,1.28,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$4==1}-gimp_graphic_novelfxl 0,7.2,14.65,5,20,0,1.06,36.14,0,1,0.5,0.85,1.93,0,0,8,1,1,1,0.5,0.95,2.89,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$4==2} -gimp_graphic_novelfxl 0,7.22892,14.6506,5,20,0,1.6,36.1,0,1,0.5,0.6,3.6,0,0,11,1,1,1,0.5,0.8,2.16,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,7,1,1,1,0.5,0.45,1
-elif {$4==3}  -gimp_graphic_novelfxl 0,7.22892,14.6506,5,20,0,1.59036,36.1446,0,1,0.5,0.590361,3.61446,0,1,17,1,1,1,0.5,0.795181,2.16867,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,7,1,1,1,0.5,0.45,1
-elif {$4==4} -gimp_graphic_novelfxl 0,7.22892,14.6506,5,20,0,1.59036,36.1446,0,1,0.5,0.855422,1.92771,0,0,8,1,1,1,0.5,0.373494,2.89157,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$4==5} -gimp_graphic_novelfxl 1,7.22892,14.6506,5,20,0,1.06024,14,0,1,0.5,0.855422,1.3253,0,0,12,1,1,1,0.5,0.8,1.28,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$4==6} -gimp_graphic_novelfxl 1,7.22892,14.6506,5,20,0,1.06024,36.1446,0,1,0.5,0.855422,1.92771,0,0,7,1,1,1,0.5,0.951807,1.92771,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1
-elif {$4==7} -gimp_graphic_novelfxl 1,7.22892,14.6506,5,20,0,1.59036,36.1446,0,1,0.5,0.590361,3.61446,0,1,18,1,1,1,0.5,0.795181,2.16867,1.25,2,0,0.15,14,0,1,0.5,0.45,2,0,1,0,1,1,1,0.5,0.45,1 -endif
-if {$5==1} -negative -endif
-if {$6==1} -gimp_cfx 10,0,0,0,0,0 -endif
-if {$7==1} -gimp_array_mirror 1,0,0,2,0,$6
-elif {$6==2} -gimp_array_mirror 1,0,0,3,0,$6 -endif
PostPosted: Sun Nov 27, 2011 2:04 pm  (#6)
where do I put the code? And is gmic 1.5.0.6. going to work on a mac...and perhaps someone like Akky would know how to download and install and what to do about earlier versions?
PostPosted: Sun Nov 27, 2011 2:12 pm  (#7)
That is a filter and it goes in the .gmic file.
PostPosted: Sun Nov 27, 2011 2:57 pm  (#8)
I have never put anything into the >plugin>gmic_gimp file...I am not yet knowledgeable about my mac files system.
PostPosted: Sun Nov 27, 2011 7:46 pm  (#9)
sorry i can't help for mac but Rod wrote a tut for all OS must be in the tutorial board
is quite simple but you must NOT add a file to a folder, the only thing to see is how save a file with a dot before the name ("should be just ".gmic" ) and were exactly
..but both are covered
anyway i will upload soon i just want be sure about the presets
PostPosted: Mon Nov 28, 2011 4:58 am  (#10)
I put it in the photoComix file.
looks good in Windows xp PC.(Gimp-2.6.11)
PostPosted: Mon Nov 28, 2011 5:49 am  (#11)
2 ton I have it working on my Mac OS X 10.6.8
(GMIC 1.5.0.6 that is)
PostPosted: Mon Nov 28, 2011 6:23 am  (#12)
@Rod
that is a temporary solution if your PC is connected to the net, all ".gmic" files (except .,gmic) are overwritten during filters updates
PostPosted: Wed Nov 30, 2011 10:09 pm  (#13)
Akky, is your version new enough to do those updates where the new filters add themselves? Mine is just old enough to not do them. And I do not know where to put the new version...if it will just overwrite the old version or not. Does the mac need a special compiled version? I forgot how I installed the gmic that I have now, I also do not know where to put .gmic files. If you know any of these answers, that would be awesome.
PostPosted: Thu Dec 01, 2011 3:42 am  (#14)
it is more simple of what you fear
you may overwrite the old files
and you have not to worry for the .gmic files they are created automatically by the first filter refresh
except the gmic file (now WITHOUT dot) that is your own , that is optional and is to handle filters that are not in the sources
cron
