It is currently Mon Oct 05, 2026 1:58 pm
 Post subject: PS resource site
PostPosted: Fri Dec 30, 2011 7:38 pm  (#1)
I came across this resource site for PS that I thought some of you might like to make use of.
http://photoshop-kopona.com/
 Post subject: Re: PS resource site
PostPosted: Fri Dec 30, 2011 8:47 pm  (#2)
so do you just download the templates and stick your photo in the appropriate layer? what I would want is to have a tutorial on how to make the template, lol. I want to be able to create those beautiful frames myself!
PostPosted: Fri Dec 30, 2011 8:53 pm  (#3)
the thing is, there are other things there from what I can see...not just the frame templates. Like brushes etc.
PostPosted: Fri Dec 30, 2011 9:56 pm  (#4)
some of which I would like, but I promised myself I would not add any more brushes until I dump some of the ones I have that I don't use! My brush folder has too many brushes in it, and I know I won't use a lot of them.
PostPosted: Fri Dec 30, 2011 10:59 pm  (#5)
Interesting site.
They've got some huge font collections - I probably don't need more fonts, but...
And the design section look like it has lots of goodies...
I'm going to need a larger disk drive soon!
PostPosted: Fri Dec 30, 2011 11:17 pm  (#6)
you could always store them on an external hd for graphics stuff!! assuming you have one that is.
PostPosted: Sat Dec 31, 2011 9:37 am  (#7)
hmmmm, maybe time for the google cloud...I could store things up there I think!
