It is currently Mon Oct 05, 2026 1:58 pm
 Post subject: Faceted Diamonds Pattern
PostPosted: Wed Mar 14, 2012 7:00 am  (#1)
I was cruising around the internet and came across a PS layer style offered by this guy in the pic below, and decided to use it for a pattern that cold be used in GIMP. I downloaded the file and Rod was Kind enough to convert it for me.
This is what it looked like after it was converted to a jpeg. Kinda blurry and dull looking.
I used Unsharp mask to raise the definition and adjusted the Levels to get this.
I carefully cropped it to make a pattern out of the center 9 segments and saved it as a .pat file. which I have attached.
After I tested the pattern, I decided to make something to show how it can be used and this is what I ended up with. I think it works very well. I scaled it to use in the text but used it full size with a little G'MIC Perspective for the background.
Enjoy!
Diamond Facets.pat [682.55 KiB]
Downloaded 777 times
 Post subject: Re: Faceted Diamonds Pattern
PostPosted: Wed Mar 14, 2012 9:02 am  (#2)
I went to the site and downloaded the style Drac; looks promising. When I saved a result, it was scaled down greatly from yours so I figure you must of scaled your result up. Anyway, thanks for the link; do (very rarely) play with PS styles so now I have an extra one for that use. :)
PostPosted: Wed Mar 14, 2012 9:22 am  (#3)
Thanks Draconian it looks really good. :)
PostPosted: Wed Mar 14, 2012 10:31 am  (#4)
Hope you don't mind a little addition stuff Drac. Used the rarely used Enlarge and Sharpen (Resynthesizer) Script-fu to increase it to 250X250 (multiple smaller passes) and then blended some additional textures in. Yes, it's seamless (it's my side specialty; lol). :)
PostPosted: Wed Mar 14, 2012 2:13 pm  (#5)
Rod, no - thank you for converting it for me.
Lyle - Don't mind at all. Just thought it looked cool and wanted to make something out of it that was usable in gimp. Knock your lights out!
