Don't expect here render of Spiderman or manga character
...instead are all geometric shapes on a transparent BG all very different but all based on the same concept
2 packs:
1 generation renders
http://photocomix-resources.deviantart. ... -177821835
2 second generation renders
http://photocomix-resources.deviantart. ... -177872726
About a possible use...just open a few as layers of a new image and then move the layers up or down to try different combinations(no need to change layer mode from Normal )..you will see by yourself...
