It is currently Tue Nov 17, 2026 3:13 am
Post new topic Reply to topic  [ 76 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: New-Theme --- Blue-Licorice-Dynamic-Metallica - windows
PostPosted: Sun Jul 22, 2012 11:39 am  (#1)
With even rounder buttons and cool scroll bar effects. :)
Metalic_Blue_Licorice_DynamicRod_D.zip [913.81 KiB]
Downloaded 1277 times
Just unzip to your themes folder. Go to edit>Preferences>Themes and load it.
 Post subject: Re: New-Theme --- Blue-Licorice-Dynamic-Metallica - windows
PostPosted: Sun Jul 22, 2012 3:39 pm  (#2)
Rod,
How does the curves background look in this theme? Is the histogram visible?
Thanks,
Partha
PostPosted: Sun Jul 22, 2012 3:50 pm  (#3)
Is this 32 or 64? Is it for Windows or Linux? What about Mac? Or is is one size fits all? :teeth
PostPosted: Sun Jul 22, 2012 3:56 pm  (#4)
Hi Molly,
Since it's a theme without any executables, it does not matter. You can use it anywhere. :)
Partha
PostPosted: Sun Jul 22, 2012 3:59 pm  (#5)
Ok, thanks Partha. I wondered cuz the other metallic one made my Gimp crash. Mentioned in one of the previous posts. I will try it
PostPosted: Sun Jul 22, 2012 5:32 pm  (#6)
partha wrote:
Rod,
Thanks,
Partha
Here it is working Partha. :)
PostPosted: Sun Jul 22, 2012 5:34 pm  (#7)
Hi Molly,
Partha
It does use the libpixmap.dll file :)
PostPosted: Sun Jul 22, 2012 5:58 pm  (#8)
Screenshot Xubuntu (Metalic_Blue_Licorice_DynamicRod_D) :
PostPosted: Sun Jul 22, 2012 6:07 pm  (#9)
That is very cool. must be a fedora bug.
I wonder why the slider corners aren't curly the way they are in Rod's and ALC's
PostPosted: Sun Jul 22, 2012 6:37 pm  (#10)
This is because the tests are on a development version of Gimp (Gimp 2.9.1).
PostPosted: Sun Jul 22, 2012 7:38 pm  (#11)
no darn wonder, anyway, it is cool.
PostPosted: Sun Jul 22, 2012 7:57 pm  (#12)
Hi Molly,
Partha
That's not a problem. On Fedora, it's probably a system file already (libpixmap.so). So you should be good to go. As long as you are not packaging your own DLLs along with the theme, it should not matter. DLLs only work on Windows. They have to be converted to shared objects (.so files) for Linux/Unix and dylibs for Macs.
Rod, thanks for the Curve Window screenshot. Most dark themes have a problem right there since the histogram is not visible. Unfortunately your screenshot is with an empty image :(, but I get the picture. :)
PostPosted: Sun Jul 22, 2012 8:53 pm  (#13)
Here you go Partha. :)
PostPosted: Sun Jul 22, 2012 9:20 pm  (#14)
For those of you who wish to replace the black text with something you can see better...do this
Open the gtkrc file in your Notepad ++ program.
Go to line # 596 and replace that line with this code
     fg[NORMAL]               = "#FFFFFF"
That makes the text much easier to see on the dialogs and the interface.
PostPosted: Mon Jul 23, 2012 5:46 am  (#15)
Rod. I certainly don't know anything about coding or how to create something so cool like this but I would like to know something. When I downloaded the theme I noticed the "bg.png" in the list and it appears that this is what the theme background is based on. Could that simply be changed out to another background of choice, say a different metallic background png with the same dimensions? I think you know where I'm going with this one.
PostPosted: Mon Jul 23, 2012 6:12 am  (#16)
Bonjour,
@Draconian
You can change bg.png by any other pattern, the size does not matter.
If you want to change the pattern name, you can edit the file "gtkrc" and replace bg.png by the name of your pattern.
PostPosted: Mon Jul 23, 2012 6:21 am  (#17)
Thanks, samj. Looks like I have some experimenting to do. I have been trying to figure out how to combine a dark theme like Aurora Midnight with the glossy buttons and bars like the OSX theme but I wouldn't have a clue how to do it.
Is there a way to change out the buttons and bars as well? This would be very usefull to know how to alter them if it was just a matter of changing out the png files but I'm guessing buttons and bars are different.
PostPosted: Mon Jul 23, 2012 6:53 am  (#18)
@Draconian
I think the best is to experiment.
In the file "gtkrc" all the changes to the images begin with #samj#
Generally these changes are on two lines:
Line 1 = old image
Line 2 = image used
To inhibit the operation of a line, # must be placed at the beginning of this line (# Indicates the beginning of a comment).
To understand the operation, I recommend starting with images of solid colors and place comments on the effect obtained.
PostPosted: Mon Jul 23, 2012 9:04 am  (#19)
The images i used are all seamless Draconian so you may want to keep that in mind also. :)
PostPosted: Mon Jul 23, 2012 10:04 am  (#20)
Yeah, that part was sort of a no brainer. I just tried to get yours to work but it doesn't show up in the Gimp Theme Selector. I put it in the Themes folder with all the others C:\Program Files\Gimp-2.0\share\themes or am I supposed to put it in the 2.6 user folder? Both paths are shown in preferences\folders so I don't see a difference except that the theme selector only reads from the 2.0 folder doesn't it?
